Zebra GC420t Monochrome Direct Thermal Desktop Printer
Quicklinx: 94P1WS00 Mfr#: GC420-100520-000
Zebra's feature-rich, competitively priced GC420t desktop printer brings performance and reliability to many low- to medium-volume, thermal transfer printing applications. The printer's space-saving design contains a powerful 32-bit processor for fast label throughput; a large memory for more graphics storage, longer label formats, and faster processing. It also includes both EPL and powerful ZPL programming languages - making it easy to integrate with other Zebra printers - while its triple connectivity option offers system integration flexibility. The GC420t delivers all the quality, durability and value you expect from Zebra.
Zebra G-Series GC420t - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
1.5 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
991 mm
Print Speed
Up to 102 mm/sec - max speed
Parallel, USB, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL, ZPL II, EPL2, EPL
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, MSI-3, Code 128A, Standard 2 of 5
Media Type
Labels, fanfold paper, tag stock
Microsoft Certification
Compatible with Windows 7
20.1 cm x 23.9 cm x 17.3 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Wired
Language Simulation
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
25 mm
991 mm
Max Printing Width
104 mm
Max Printing Length
991 mm
Media Thickness Range
0.08 mm - 0.18 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38 mm
Media Feeders
1 x manual - 1 roll
1 x USB , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel
FCC Class B certified, TUV, NOM, KCC
Frequency Required
50 - 60 Hz
5 °C
41 °C
10 - 90% (non-condensing)
20.1 cm
23.9 cm
17.3 cm
1.5 kg
Ink (6)
94P1 Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) In Stock £33.71
94P1 Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls In Stock £174.28
94P1 Zebra Z-Select 2000D 57x32mm In Stock £108.46
94P1 Zebra 12 ROLLS Z-SLCT 2000D 51X25MM In Stock £102.43
94P1 Zebra Ribbon Wax/Resin 110mm x 74m In Stock £50.84
94P1 Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. In Stock £115.82
Other bundles (2)
94P1 Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l In Stock £145.23
94P1 Zebra Z ONECARE SEL >30 DAYS PURCHAS In Stock £319.67
