Product
Zebra G-Series GX420d Direct Thermal Label Printer
Quicklinx: 9YPKWS00 Mfr#: GX42-202720-000
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Direct thermal
£405.39 ex VAT
£486.46 inc VAT
The direct thermal GX420d is extra compact to fit in congested workspaces and produces 203dpi print resolution at speeds up to 6 inches per second. It increases your media choices and application flexibility with cutter and peeler.
Zebra GX Series GX420d - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.4 kg
United Kingdom, Europe
Max Media Size
Roll (10.8cm)
Min Media Size (Custom)
19 mm x 9.7 mm
Max Media Size (Custom)
108 mm x 991 mm
Print Speed
Up to 152 mm/sec - max speed
Max Resolution (B&W)
203 dpi
USB, serial, Wi-Fi
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB (68 MB)
Language Simulation
ZPL, ZPL II, EPL2
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, Plessey, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A, Standard 2 of 5
Media Type
Continuous forms, receipt paper, fanfold paper, continuous paper labels, tag labels, die cut labels
Print server - IEEE 802.11b, IEEE 802.11g
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
1 year warranty
17.1 cm x 20.9 cm x 15.2 cm
Printer Type
Printer
Print Speed
Up to 152 mm/sec - max speed - 203 dpi
Wireless
USB, serial, Wi-Fi
203 dpi
Language Simulation
ZPL, ZPL II, EPL2
Fonts Included
21 x bitmapped , 1 x scalable
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB (installed) / 68 MB (max)
Media Handling
Media Type
Max Media Size
Roll (10.8cm)
19 mm x 9.7 mm
108 mm x 991 mm
Media Sizes
Roll (1.9 - 10.8 cm)
Max Printing Width
104 mm
Media Thickness Range
0.08 mm - 0.2 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 12.7 mm, 37.1 mm
Media Feeders
1 x manual - 1 roll - Roll (10.8cm)
Print server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
1 x USB cable
TUV, VCCI, C-Tick, EN 61000-3-2, IEC 60950, EN55024, EN55022 Class B, CB, FCC Part 15 B, CCC, IRAM, AAMI
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Power Factor Correction
Software Included
Drivers & Utilities
Limited warranty - 1 year , Limited warranty - printhead - 6 months
5 °C
41 °C
10 - 90% (non-condensing)
17.1 cm
20.9 cm
15.2 cm
1.4 kg
Weight (Shipping)
3.2 kg
Type: Printer
Wireless Capability: Wireless
Max Print Speed: [N/A]
Brand: Zebra
Price Range Ex VAT: 300 - 500
