With the GK420t direct thermal/thermal transfer printer, use Zebra's easy ribbon-loading thermal transfer technology to produce crisp, long lasting label images, or direct thermal technology to print receipts and labels for indoor, short-term use. The GK420t is well-suited to any industry, and provides the same print speeds and connectivity options as the GK420d.
- Zebra GK Series GK420t - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 2.1 kg
- Localisation
- Europe
- Max Media Size
- Roll (10.8cm)
- Min Media Size (Custom)
- 19 mm x 9.7 mm
- Max Media Size (Custom)
- 108 mm
- Print Speed
- Up to 127 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, LAN
- RAM Installed (Max)
- 8 MB SDRAM
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL, ZPL II, EPL2
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, MacroPDF417, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A
- Media Type
- Labels, continuous forms, tag stock
- Networking
- Print server - Ethernet, Fast Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 19.4 cm x 25.4 cm x 19.1 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
- Localisation
- Europe
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 203 dpi
- ZPL, ZPL II, EPL2
- Fonts Included
- 1 x bitmapped , 1 x scalable
- Barcodes
RAM
- 8 MB
- Technology / Form Factor
- SDRAM
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (10.8cm)
- 19 mm x 9.7 mm
- 108 mm
- Media Sizes
- Roll (10.8cm)
- Max Printing Width
- 104 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.2 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual
- Networking
- Print server
- Network Controller Name
- ZebraNet 10/100 Print Server
- Data Link Protocol
- Connections
- 1 x USB , 1 x LAN - RJ-45
- TUV, VCCI, C-Tick, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Power Factor Correction
- 5 °C
- 41 °C
- 10 - 90% (non-condensing)
- 19.4 cm
- 25.4 cm
- 19.1 cm
- 2.1 kg
- Weight (Shipping)
- 4.1 kg
Ink (7)
Zebra RIBBON WAX 2300 110MM X 74M(Box of 12) | In Stock | £33.71 |
Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls | In Stock | £174.28 |
Zebra Z-PERF 1000D 80 RECEIPT 102MM 100 METERS C-25MM BOX OF 12 | In Stock | £94.68 |
Zebra Z-Select 2000D 57x32mm | In Stock | £108.46 |
Zebra 12 ROLLS Z-SLCT 2000D 51X25MM | In Stock | £102.43 |
Zebra Ribbon Wax/Resin 110mm x 74m | In Stock | £50.84 |
Zebra Direct 1100 Perforated Matte Permanent Rubber Adhesive Paper - 16440 pcs. | In Stock | £115.82 |
Other bundles (1)
Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l | In Stock | £145.23 |
