Zebra 1ROLL ZSLCT 2000D 102 X 64 MM 12 rolls
Quicklinx: 835CWS00 Mfr#: 800264-255
Type: Labels
Technology: Direct Thermal
Hurry, only 3 left in stock!
£133.45 ex VAT
£160.14 inc VAT
Direct 2100 is a white smooth coated direct thermal label that produces black visible light images at speeds of up to 152 mm per second. The permanent rubber-based adhesive will adhere to most surfaces, and can be used at temperatures as low as -40ยบ C. Ideal for packaging and labeling promotional products and chilled or frozen products.
This product is compatible with A300, DA402, Ht-146, LP 2642, LP 2742, LP 2844, LP 2844-Z, T402, TLP 2844, TLP 2844-Z, TLP 3742, TLP 3842, TLP 3844-Z printers.
Zebra Z-Select 2000D - labels - 13200 label(s) - 63.5 x 101.6 mm
Labels
Product Material
Paper
Adhesive Type
Permanent acrylic adhesive
Coating
Top coated
Media Size
63.5 x 101.6 mm
Printing Technology
Direct thermal
Media Colour
White
Card / Label Qty per Sheet/Roll
1100
Qty of Media with Cards
12 roll(s)
Included Qty
13200 label(s)
Compatible with
LP 2642, 2742, 2844, 3642, 3742; Orion; TLP 2642, 2742, 2844, 3642, 3742; Zebra DA402, Ht-146, T402; GK Series GK420t; G-Series GC420t; GX Series GX420t; LP 2742, 2844; Stripe A300; TLP 2742, 2844, 2844-Z, 3742, 3842, 3844-Z
Media
Media Type
Labels
Product Material
Paper
Adhesive Type
Coating
Top coated
Media Sizes
63.5 x 101.6 mm
Printing Technology
Direct thermal
Media Colour
White
1100
12 roll(s)
Included Qty
13200 label(s)
Colour Category
White
Compatible with
Eltron LP 2642, 2742, 2844, 3642, 3742 , Eltron Orion , Eltron TLP 2642, 2742, 2844, 3642, 3742 , Zebra DA402, Ht-146, T402 , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420t , Zebra LP 2742, 2844 , Zebra Stripe A300 , Zebra TLP 2742, 2844, 2844-Z, 3742, 3842, 3844-Z
Type: Labels
Brand: Zebra
Price Range Ex VAT: 100 - 150
