Product
Zebra 110XI4 203DPI Label Printer with Rewind
Quicklinx: CMRJWS00 Mfr#: 112-80E-00203
The workhorse of the Xi product line, the 110Xi4 was built on the legacy of the Xi series of products. The 110Xi4 was developed to improve overall operational productivity and efficiency in a variety of environments.
Zebra Xi Series 110Xi4 - label printer - monochrome - thermal transfer
Printer Type
Label printer - thermal transfer - monochrome
22.7 kg
Max Media Size
Roll (20.3 cm)
Max Media Size (Custom)
102 mm x 3810 mm
Max Resolution (B&W)
203 dpi
Image Enhancement Technology
Multi-level Element Energy Equalizer
Parallel, USB, LAN, serial
133 MHz
RAM Installed (Max)
16 MB SDRAM
Flash Memory Installed (Max)
8 MB
Language Simulation
ZPL II, Extensible Mark-up Language (XML)
Barcodes
Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, ISBT 128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Code 2 of 5, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, PLANET, TLC39, Code 128B, Code 128C, Code 128A
Media Type
Labels, continuous forms, fanfold paper
Total Media Capacity
1 roll
Print server - Ethernet, Fast Ethernet
AC 120/230 V
Microsoft Certification
Compatible with Windows 7
26.2 cm x 51.8 cm x 39.4 cm
Printer Type
Printer
Built-in Devices
Status LCD
Wired
203 dpi
Language Simulation
Fonts Included
1 x bitmapped , 1 x scalable
Barcodes
133 MHz
RAM
RAM Installed (Max)
16 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
8 MB
Media Handling
Media Type
Max Media Size
Roll (20.3 cm)
102 mm x 3810 mm
Media Sizes
Roll (20.3 cm)
Media Thickness Range
0.76 mm - 0.305 mm
Roll Maximum Outer Diameter
203 mm
Roll Core Diameter
76 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (20.3 cm)
Print server
Network Controller Name
ZebraNet 10/100 Print Server
Expansion Slots
1 x parallel - 36 PIN Centronics , 1 x RS-232/422/485 , 1 x USB , 1 x LAN - RJ-45
Peeler, rewind
Paper sensor
FCC Class B certified, VCCI, C-Tick, BSMI, EN 60950, EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, CCC, IEC 60950-1, KCC, GOST-R, S Mark, cTUVus
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
5 °C
20 - 85%
26.2 cm
51.8 cm
39.4 cm
22.7 kg
