105°C solid capacitor guarantees stability at high temperatures, frequencies and currents. Built-in active PFC circuit provides high power factor and efficiency. Full bridge and LLC resonant circuits applied.
Modular cable type
DC output modular cables to organize cables and for better efficiency. -
High quality components
105°C solid capacitor guarantees stability at high temperatures, frequencies and currents. -
Active PFC and LCC resonant circuit
Built-in active PFC circuit provides high power factor and efficiency. Full bridge and LLC resonant circuits applied. -
Secondary protection IC
Built-in circuits protects against voltage surges, current surges, power surges, low tension, short circuiting, and overheating. -
Ultra quiet 140 mm for smart cooling
Smart fan control system optimizes thermal control while minimizing noise levels. -
Flat type cable
Neatly organized flat-type modular cables help to increase air flow inside the case.
- ZALMAN ZM1250 Platinum - power supply - 1250 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- 80 PLUS Certification
- 80 PLUS Platinum
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1250 Watt
- Output Current
- +3.3V - 25 A / 0 A , +5V - 25 A / 0 A , +12V1 - 45 A / 1 A , +12V2 - 65 A / 0 A , -12V - 0.8 A / 0 A , +5VSB - 4 A / 0 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x 4 PIN internal power , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- Cooling System
- 140 mm fan
- Included Accessories
- Cable ties, thumbscrews
- 15 cm x 20 cm x 8.6 cm
- 5-year warranty
- ATX12V 2.3
- PSU Form Factor
- ATX
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1250 Watt
- Output Current
- Efficiency
- 93%
- 80 PLUS Platinum
- MTBF
- 100,000 hours
- Cooling System
- 140 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Quad SLI ready, CrossFireX ready
- UL, CB, FCC, RoHS, ErP Ready, KC
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 20 - 90%
- 15 cm
- 20 cm
- 8.6 cm
