Zalman Fan Extension Cable
Quicklinx: 9V2GWS00 Mfr#: ZM-EC1
The Multi-connector supplies +5V or +12V power to any additional fan that a user may wish to install. Connect it to the power supply's output connector and simply attach the fans to the 3-pin connectors at the other end.
ZALMAN Multi Connector 1 - fan power extension cable - 75 cm
Fan power extension cable
Length
75 cm
Connector
3 PIN internal power - male
Connector (Second End)
3 PIN internal power - female
Length
75 cm
Connector
