Yeelight Blue Screw (E27)
Quicklinx: B1DYWS00 Mfr#: BUL27BL0101
Light that keeps up with you - Set a timer for automatic turn-on/off.
The Yeelight bulb will go to sleep with you at night, and wake you up in the morning, as natural as a sunrise.
Preserve your memories in Flowing Colour
Our patented software technology Flowing Colour analyses your photo albums for colour schemes to help you recreate an atmosphere you experienced years ago, or bring you back to the trip of your lifetime.
Throwing a party?
Our Yeelight bulbs can sync their colour changes to the music, for scene lighting with a beat
Colour your life green
Start saving monet today with Yeelights environmentally friendly light bulbs
Statefull Operation.
These are statefull products (unlike others). If you turn off competitor products using a wall switch or plug and then plug it in or turn it on again, the lamp won't light. With Yee light this is not the case. If it was on when the power was removed, it will be on when the power resumes.
Easy Installation - No Gateway
Control up to 10 lamps from one phone
Perfect Software Smooth Dimming
500 lumen equivalent to a 40 watt light bulb
7 times the lifespan of a traditional incandescent Lamp
Up to 85% Energy Saving
Up to 16 million colours
Effects
Flowing Colour
Wake Up
Good Night
Disco Time
  • iOS & Android App Controlled Smart LED Bulb via the Bluetooth wireless connection
  • Easy installation and No Need of using a gateway or any cable
  • Great features such as: Disco Time, Flowing Colour and Auto Time On/off
  • Can display 500 lumens high quality white light and a wide variety of 16 Million Colours
  • 20 Times longer lifespan, Energy Saving up to 88%
Supported mobile phones:
iOS: iPhone(4s,5,5c,5s);iPod touch(5th generation);iPad (3rd,4th generation);iPad mini;
Android: XiaoMi 2S,SAMSUNG NoteII,Note3,Galaxy S4,Nexus4 and smartphones that support BLE (System version is 4.3+)
Yeelight - LED light bulb - E27 - 6 W - RGB/white light - 6500 K
Light Source Type
LED light bulb
Socket Type
E27
Wattage
6 W
Colour of Illumination
RGB/white light
Colour Temperature
6500 K
Luminous Power
500 lumens
Dimmable
Communications Technology
Bluetooth
AC 100 - 240 V
Frequency Required
50/60 Hz
Light Source
LED light bulb
Socket Type
E27
Wattage
6 W
RGB/white light
Colour Temperature
6500 K
Luminous Power
500 lumens
Beam Distance
30 m
Dimmable
Lifetime
20000 hours
iOS compatible, controlled via Bluetooth 4.0, indoor usage, remote controlled
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub
Not needed
Communications Type
Product-to-product
Bluetooth
CCC, FCC
Warranty
1 year
Diameter
50 mm
Length
104 mm
155 g
80 mm x 75 mm x 145 mm / 300 g
