Experience real 5.1-channel surround sound with Yamaha’s exclusive Digital Sound Projector technology. The YSP-1400 features dual built-in subwoofers for deep, rich bass and Bluetooth wireless technology that lets you quickly stream music from your smartphone, tablet or computer.
Immerse yourself in real surround sound
Yamaha Digital Sound Projectors create actual (not virtual) surround sound by producing beams of sound that reflect off the walls in controlled directions, delivering an amazingly immersive experience. The position of the beams can be adjusted for your listening location by using the included remote control or a free downloadable app. -
All-in-one design keeps your room clutter-free
No need for a separate subwoofer unit! The YSP-1400 is equipped with eight array speakers on the front and two down-firing subwoofers integrated into the feet of the sound bar. Combined, they deliver sound with exceptional power and presence. -
Dual built-in subwoofers deliver clear, rich bass
With large 3-1/4" subwoofer drivers built into the feet of the sound bar combined with high-rigidity bass reflex ducts and a large-volume cabinet, the YSP-1400 delivers clear, rich and deep bass for movie sound effects and music. The independent right and left channel configuration provides superior sound imaging. -
Compatible with various surround sound formats
The YSP-1400 is compatible with popular surround sound formats, such as Dolby Digital and DTS Digital Surround, so you get the full effect of multichannel movie sound. -
Four CINEMA DSP programs
Yamaha's ultra-sophisticated CINEMA DSP technology creates thrillingly realistic soundscapes in any room. You can select four different program, including movie, music, sports and game. -
Bluetooth wireless music streaming from your smartphone or tablet
Fill your home with music the quick and easy way! Stream music from Bluetooth-compatible smartphones, tablets and computers. The YSP-1400 can also be set in Bluetooth standby mode, enabling the bar's power to turn on or off automatically for energy-saving convenience. -
Single cable for easy connection
In a typical installation, the YSP-1400 connects to a TV via a single cable, so setup is quick and easy. Two digital inputs types are available, one optical and one coaxial. In addition, the YSP-1400 offers two analog inputs (3.5 mm stereo and a dual RCA) allowing it to accommodate additional audio sources if desired. -
Free control app for easy operation
The YSP-1400 is compatible with a Home Theater Control App (HT Controller), available for free download for Apple iOS and Android devices. The app makes it easy to control the sound bar via a Bluetooth connection, including input selection, surround modes and detailed settings for the sound beams. -
The YSP-1400 connects to a TV via a single cable, so setup is quick and easy. It provides two digital input terminals (optical/coaxial). -
TV remote repeater for signal transmission
Even if the YSP-1400 blocks the TV's remote control signal, the TV Remote Repeater on the back transmits the signal to the TV so operation is not affected. -
Learning function allows operation with the TV remote control
The YSP-1400 can "learn" the TV remote control operation, so you can use the TV remote control to turn the YSP-1400 on and off and to adjust its volume. -
Clear Voice Makes Dialog and Narrations Easy to Hear
Clear Voice raises the level of dialog and narrations while maintaining overall sound quality. Movies and TV shows, sports commentary and news broadcasts are more clearly audible. -
UniVolume maintains the same volume level
This welcome feature, made possible by Yamaha-developed technology, maintains a consistent volume level between different channels, programs, commercials and input sources. It can be switched on and off.
- Yamaha Digital Sound Projector YSP-1400 - sound bar - wireless
- Product Type
- Sound bar - 5.1-channel
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Continuous Power
- 76 Watt
- Frequency Response
- 45 - 22000 Hz
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- AAC
- Speaker Details
- Sound bar - surround x 8 - 2 Watt - 500 - 22000 Hz - active , Sound bar - subwoofer x 2 - 30 Watt - 45 - 500 Hz - active
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Built-in Decoders
- Dolby Digital, DTS decoder
- 100 cm x 13.3 cm x 9.6 cm
- 4.3 kg
- Product Type
- Enclosure Design
- Bass reflex
Speaker System
- Speaker Type
- Active
- Continuous Power
- 76 Watt
- 45 - 22000 Hz
- Magnetic Shield
- Amplifier
- Integrated
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 10 m
- Built-in Decoders
- Audio Formats
- AAC
- Controls
- Power on/off, volume
- Additional Features
- UniVolume technology, smartphone remote controlled
Speaker System Details
- Speaker Details
- Sound bar - surround x 8 - 2 Watt - 500 - 22000 Hz CFR - active , Sound bar - subwoofer x 2 - 30 Watt - 45 - 500 Hz CFR - active
- Driver Details
- Sound bar: 8 x full-range driver - 1 1/8" , Sound bar: 2 x subwoofer driver - 3.25"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Subwoofer output (RCA) , SPDIF input (TOS Link) , SPDIF input (RCA) , Audio line-in (RCA x 2)
- Included Accessories
- Digital audio cable (optical), remote control, 2 AAA batteries
- Power Source
- AC power adapter
- 24 Watt
- 100 cm
- 13.3 cm
- 9.6 cm
- 4.3 kg
