Yamaha Music Cast mid Range SoundBar
Quicklinx: CLL2WS00 Mfr#: YAS306B
£297.65 ex VAT
£357.18 inc VAT
Featuring a stylish design, this Sound Bar makes it easy to enjoy surround sound with profuse presence. It also outputs generous bass from two built-in subwoofer units. MusicCast compatible, so it’s ready to expand your range of video and audio entertainment.
  • MusicCast
    Use all your MusicCast products together or separately, it's completely up to you. Control it, all from one app, designed to be intuitive, quick and simple to use. Use a soundbar, a wireless speaker, an AV Receiver, Hi-Fi audio whichever suits you best, mix and match then expand your MusicCast system as time goes on. The MusicCast system brings everything to everywhere for everyone.
  • Enjoy all your music sources
    MusicCast employs a high performance wireless network to deliver music and audio enjoyment. It can stream digital music content from your smartphone, PC or NAS to other MusicCast devices in your home. It can also share the music from external devices such as a TV or Blu-ray player connected to the YAS-306. Audio content from Bluetooth-connected smartphones or tablets can also be streamed to MusicCast devices in multiple rooms.
  • Stylish body for a beautiful installation
    With a rounded form that will help to beautify your interior, the YAS-306 can be placed on a shelf or hung on a wall, whichever style suits your room.
  • High quality material
    The YAS-306 body has a high-grade covering made of a materials that doesn't show dust so much.
  • Powerful surround sound from any position
    The YAS-306 unit includes two built-in subwoofer units for strong bass output, plus a unique bass reflex port for further boost. It also has two middle size woofer units and tweeter units that deliver well-balanced midrange sound and clear high tone. Whether used horizontally or vertically, or mounted on a wall, you're assured of getting massive bass output for a powerfully dynamic surround sound experience.
  • Specially designed speaker unit
    The YAS-306 features a high quality speaker unit designed especially for it. The tweeter, woofer and subwoofer units are all well balanced and optimized to produce both massive bass with excellent response and clear, highly listenable treble.
  • Stream via Bluetooth or AirPlay
    You can hear all the music sources from your smartphone via wireless Bluetooth or AirPlay connection. You can play music from music apps, radio apps, or video hosting services.
  • Bluetooth output for convenient music streaming
    The YAS-306 is equipped with the latest Bluetooth technology, making wireless operation more convenient than ever. You can stream music from the YAS-306 to Bluetooth headphones for private listening or to Bluetooth speakers.
  • Five sound programs
    Providing sound programs with an overwhelming sense of presence and dynamic bass reproduction, the YAS-306 raises the emotion and excitement level so it's like you're watching the movie at a theater and listening to music at a live event.
  • Compressed Music Enhancer
    The Compressed Music Enhancer restores frequency response lost during digital compression, so your music sounds the way it should. It is optimized for Bluetooth audio transmission for vivid, lively sound quality during wireless playback. The function engages automatically when a compressed source is played.
  • Clear Voice
    Clear Voice raises the level of dialog and narrations while maintaining overall sound quality. Movies and TV shows, sports commentary and news broadcasts are more clearly audible.
Yamaha MusicCast YAS-306 - sound bar - wireless
Sound bar - 2.1-channel
Internet radio
Enclosure Design
Bass reflex
Speaker Type
Active
Nominal Output Power
120 Watt
Frequency Response
55 - 23000 Hz
Amplifier
Integrated
Ethernet, Bluetooth, Wi-Fi
AirPlay
DLNA
Streaming Services
Pandora, vTuner, Spotify
Audio Formats
WAV, WMA, AAC, AIFF, MP3, FLAC, Apple Lossless
Speaker Details
Sound bar - stereo x 2 - 30 Watt - at 1 kHz - 10% THD - 6 Ohm - active , Sound bar - subwoofer - 60 Watt - at 100 Hz - 10% THD - 3 Ohm - active
Built-in Decoders
SBC decoder, DTS Digital Surround, Dolby Audio
Sound Effects
Air Surround Xtreme, 3D 7.1 virtual surround sound
95 cm x 13.1 cm x 7.2 cm
4.9 kg
Internet radio, Advanced Yamaha Active Servo Technology (Advanced YST) II
Enclosure Colour
Enclosure Design
Bass reflex
Speaker System
Speaker Type
Active
120 Watt
Frequency Response
55 - 23000 Hz
Amplifier
Integrated
Sound Effects
IEEE 802.3 (Ethernet), Bluetooth 2.1 EDR, IEEE 802.11b/g/n
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Low Complexity Subband Coding (SBC)
Transmission Range
10 m
AirPlay
DLNA
Internet Streaming Services
Built-in Decoders
Audio Formats
Controls
Input selector, mute, power on/off, volume
Speaker System Details
Speaker Details
Sound bar - stereo x 2 - 30 Watt - at 1 kHz CFR - 10% THD - 6 Ohm - active , Sound bar - subwoofer - 60 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
Driver Details
Sound bar: 2 x subwoofer driver - 3" , Sound bar: 2 x woofer driver , Sound bar: 2 x tweeter driver - 0.75"
Connector Type
Digital audio input (optical) (TOS Link) , Digital audio input (coaxial) (RCA) , Audio line-in (RCA x 2) , Subwoofer output (RCA) , Network (RJ-45) , USB (4 PIN USB Type A)
Digital audio cable (optical), remote control, batteries, 2 spacers
Power Source
AC power adapter
22 Watt
95 cm
13.1 cm
7.2 cm
4.9 kg
Brand: Yamaha
Price Range Ex VAT: 150 - 300
