Yamaha 7.1 22W Bluetooth Soundbar - Black
Quicklinx: CLL0WS00 Mfr#: YAS105B
Audio System Type: Soundbar
Surround system: 7.1 channel
£207.06 ex VAT
£248.47 inc VAT
The stylish, flexible design allows wall mounting or placement on a TV stand.
The YAS-105 delivers a total of 120 W (60 W + 30 W + 30 W) of very powerful and dynamic sound from its slim and stylish cabinet. In addition to the left and right speakers, it has two built-in subwoofers and two balance dome tweeters. This contributes to clear separation between mid and high range tones. For music, the mid-high sounds become more transparent and for movies, the sound is much more dynamic.
AIR SURROUND XTREME is Yamaha's unique virtual surround technology, delivering full, rich sound with a cohesive sense of surround placement. Enjoy immersive surround sound with all kinds of audio sources, from movies to sports and music.
  • Versatile style
  • Powerful sound with excellent full-range quality
  • AIR SURROUND XTREME provides spacious home theater experience
  • Dual built-in subwoofers powerfully reproduce bass sounds
    The YAS-105 employs dual subwoofers inside the cabinet that point upward. Even without a standalone subwoofer, you can enjoy powerful bass sound. Since the sound is output upward, the bass response is very quick and punchy. For music reproduction, the bass notes and rhythm is very accurate.
  • Bass reflex port contributes to deeper, richer bass
    The YAS-105 employs a bass reflex port that has adequate length to provide outstanding bass response together with the large volume cabinet. The duct outlet is shaped like a trumpet bell, which reduces air output noise for better sound clarity.
  • Slim body for a beautifully stylish installation
    Whether on a flat surface or on a wall, the YAS-105 has the right style for perfect installation. With a height of only 53 mm (2-1/8"), it won't block the screen so you can set it right in front of the TV, and it will also look attractive mounted on a wall. It connects to your TV via a single cable, so setup is quick and easy.
  • Bluetooth wireless music streaming from your smartphone or tablet
    Enjoy the sound of music or movies from your smartphone or tablet wirelessly. While watching the screen, it's easy to perform select, play and stop operations, as you enjoy sound backed by the power of the YAS-105. There is also a Bluetooth standby mode, so by linking to Bluetooth on/off via the terminal, you get the convenience of the YAS-105 turning on and off automatically.
  • Power saving design
    The YAS-105 features low power consumption of only 0.4 W.
  • Versatile connectivity
    There are four input terminals: optical, coaxial, stereo mini and Bluetooth. There is also a subwoofer output terminal.
  • Clear Voice makes dialog and narrations easy to hear
    Clear Voice raises the level of dialog and narrations while maintaining overall sound quality. Movies and TV shows, sports commentary and news broadcasts are more clearly audible.
Yamaha YAS-105 - sound bar - for TV - wireless
Sound bar - for TV
Speaker Type
Active
Nominal Output Power
120 Watt
Frequency Response
55 - 23000 Hz
Amplifier
Integrated
Bluetooth
Audio Formats
AAC
Speaker Details
Sound bar - stereo x 2 - 30 Watt - 160 - 23000 Hz - 6 Ohm - 2-way - active , Sound bar - subwoofer - 60 Watt - 55 - 160 Hz - 3 Ohm - active
Built-in Decoders
Dolby Digital
Sound Effects
Air Surround Xtreme
89 cm x 13.1 cm x 5.3 cm
4 kg
Sound bar - for TV
Enclosure Colour
Speaker System
Speaker Type
Active
120 Watt
Frequency Response
55 - 23000 Hz
Amplifier
Integrated
Sound Effects
Air Surround Xtreme
Bluetooth 2.1 EDR
Bluetooth Profiles
Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Low Complexity Subband Coding (SBC)
Transmission Range
10 m
Built-in Decoders
Dolby Digital
Audio Formats
AAC
Controls
Input selector, mute, power on/off, volume, bass extension
Speaker System Details
Speaker Details
Sound bar - stereo x 2 - 30 Watt - 160 - 23000 Hz CFR - 6 Ohm - 2-way - active , Sound bar - subwoofer - 60 Watt - 55 - 160 Hz CFR - 3 Ohm - active
Driver Details
Sound bar: 2 x mid/woofer driver - 2-1/8" , Sound bar: 2 x tweeter driver - 3/4" - balanced dome , Sound bar: 2 x subwoofer driver - 3"
Connector Type
SPDIF input (TOS Link) , SPDIF input (RCA) , Audio line-in (mini-phone stereo 3.5 mm) , Subwoofer output (RCA)
Digital audio cable (optical), remote control, 2 AAA batteries, spacer, wall template
Power Source
AC power adapter
22 Watt
89 cm
13.1 cm
5.3 cm
4 kg
Brand: Yamaha
Price Range Ex VAT: 150 - 300
