HomeMonitor Indoor lets you see and hear what's happening around your home or business from anywhere, on your pc, smartphone or tablet. Easy to set up, this entry level security camera is perfect for watching entrances, observing pets and minding your loved ones, day and night. HomeMonitor Indoor instantly alerts you when motion is detected. Watch live or review your last 7 days’ of recordings securely stored in your online cloud account, safe from theft. Unlike other cloud video recording solutions, storage is absolutely free. Keep adding more indoor and outdoor HomeMonitor cameras, and manage them all from one account.
Primary Features & Benefits
- FREE cloud recording: Save the clips that matter. Every movement detected during the last 7 days is recorded and stored in your secure online account, ready to view free of charge, no monthly fees.
- Safe and Secure: Even if your security camera is vandalised or stolen, your clips are safe in the cloud and fully protected utilising Industry standard encryption. Save your clips for 30 days by upgrading to HomeMonitor Plus.
- Quick & Easy Setup: Works straight out of the box, with no recording device required. Plug in the power, connect to your network and activate your online account, that's it - no technical skills necessary.
- Personalised Notifications: HomeMonitor instantly alerts you on your smartphone when motion has been detected. Easily set up daily recording schedules and custom recording zones, on areas such as doorways and windows; to ensure you're only alerted when it matters.
- Internet Friendly: HomeMonitor only records when something happens so it doesn’t need to constantly battle for the internet with other connected mobile devices in your home. Enjoy minimal impact on your surfing and download speeds and stay within your data allowance
- Access on the go: View your recorded videos and stream live from anywhere at any time, using our free mobile IOS & Android apps*
*IOS 7.0 and above, Android 4.0 and above
Secondary Features & Benefits
- See in the dark - powerful infrared LEDs deliver clear night vision for 24 hour surveillance producing crisp images in total darkness up to 15M away. What's more, it's automatic, so it only comes on when you need it!
- Build to your security needs: Monitor multiple locations directly from your phone, adding as many Wi- Fi cameras to your account as necessary. The optional HD Pro, weatherproof camera allows monitoring of outdoor sites, such as driveways and gardens to complete your home security system.
- Unobtrusive: HomeMonitor Indoor blends seamlessly into your home with its minimalist design and small form factor. It's perfect for watching entrances, observing your pets and minding your loved ones. It also comes with its own stand for easy placement on tables, walls or ceilings.
- Never miss a moment: on-board SmartBuffer technology uses the camera's internal memory to record the moments leading up to the event, giving you the whole story.
- Keep recordings permanently: Download videos to your PC for free directly from your HomeMonitor™ account. Save as many videos as you like from the last 7 days.
- Dependable: HomeMonitor supports the latest Wi-Fi standards to maintain a strong and secure connection to your network, capturing every important moment. Should you prefer a wired connection, just connect the camera directly to your router.
Box Contains
- HomeMonitor Indoor Camera
- Stand/Wall Mount
- 3m/10ft power supply with UK/US/EU plugs
- 1m/3ft network (Ethernet) cable
- User guide
Easy to install
Due to the unique way the Y-cam has been designed, you don't need to be "tech-savvy" to install and use cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish. -
Affordable
Y-cam have taken advances in computer technologies and applied them to security cameras, enabling access to powerful features via the Internet, mobile phone and email, all at an affordable price. -
High quality
Y-cam cameras are fitted with high quality lenses and image processing technology. They produce excellent video, allowing recognition and identification of subjects that have been used successfully by the British Police in identifying, charging and prosecuting intruders. Y-cam uses MPEG-4 compression technology and matched resolutions to minimize bandwidth usage and cost, as well as maximizing performance. -
View from anywhere
The Internet and computer technology inside a Y-cam allows you to view your cameras from anywhere in the world via the Internet. Either on PC, Mac, Linux, iPhone, Android, Blackberry or other Internet-enabled mobile phone or browsing devices. -
Detect motion
The Y-cam can detect motion, and trigger events when motion occurs. 4 different 'zones' can be set on the image, and sensivity adjusted independantly. Unlike conventional activity detection, the Y-cam uses vector information to detect motion, therefore achieving better reliability against false alarms. -
Receive alerts when activity detected
The Y-cam can send you an email when motion is detected, and even include a snapshot of the event. The alert function can also upload images to websites, or activate recording of the event on to memory card. -
See in the dark with night vision
See up to 15 meters in pitch black darkness. Night vision enabled Y-cams utilize powerful infrared LEDs to provide high levels of "invisible" light in dark environments. The intelligent photosensitive components can automatically turn on the LEDs in low light conditions or the user can select "moonlight view" which superimposes frames together to increase brightness (frame integration). -
Record footage internally to memory card
MicroSD enabled models allow you to plug in a microSD memory card to record footage continuously, periodically or on triggered alarm events. Just like the live view, you can view this footage from anywhere, or download it to anywhere. -
Schedule automatic backup of recorded footage
Automatically backup stored footage to a local or remote computer from any microSD enabled Y-cam. Ideal for backup, redundancy or additional security should the camera itself be a victim. -
Control who has access to your Y-cams
Secure password access to the Y-cam ensures no-one else can access the cameras without your authorization. The Wi-Fi connection is protected with WEP, WPA or WPA2 encryption for security. -
Blend in to your surroundings
Y-cam's sleek and unobtrusive design allows it to blend in to the home or office, rather than stand out like a traditional security camera. -
Re-use it, move it, use it again
The Y-cam cameras are easy to move and re-install. So as your needs change, you can change what the camera does for you. As your baby grows up, use it to keep an eye on the kids in the garden, broadcast family festivities to distant relatives, then check the kids get home from school, or check if their friends have joined them! The Y-cam can be wall-mounted, ceiling-mounted, or placed on a flat surface using the supplied camera stand.
- Y-cam HomeMonitor Indoor - network surveillance camera
- Network surveillance camera - indoor
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Ethernet 10Base-T/100Base-TX
- Cables Included
- 1 - network cable - 1 m
- Wired
Camera
- Colour - Day&Night - indoor
- Network Interface
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Cables Included
- 1 x network cable - 1 m
- Power Device
- Power adapter - external
