Your basket is empty
XYZ ABS Filament 1.75mm Purpurin
Quicklinx: BPRLWS00 Mfr#: RF10XXEU07E
XYZprinting produces high quality ABS filaments that offer longer lifespan, better impact resistance, and finer appearance that makes it suitable for external components or model parts. Additionally, you can easily use common modeling tools to decorate, assemble or connect different parts to create your perfect. Easy to install filament cartridges available in many vivid colors. XYZprinting filament cartridges are designed and tested to ensure that there is no distortion in color or form ensuring your designs come out perfect every time.
XYZprinting - violet - ABS filament
ABS filament
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Printing Colour
Violet
Compatible with
Da Vinci 1.0, 1.0 Aio
Shipping Weight
1.2 kg
Consumable
Consumable Type
ABS filament
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Violet
Nozzle Temperature
210 °C
Glass Transition Temperature
90 °C
Included Qty
1-pack
Compatible with
XYZprinting da Vinci 1.0, 1.0 Aio
