Product
XYZ ABS Filament 1.75mm Neon Yellow
Quicklinx: BPRFWS00 Mfr#: RF10XXEU0DE
XYZprinting produces high quality, long lasting, ABS filaments that offer better impact resistance making it suitable for external components or model parts. Additionally, you can easily use common modeling tools to decorate, assemble or connect different parts to create your next big project.
  • Put to the test
    XYZprintings filaments have been extensively tested on da Vinci 3D printers and XYZware for high-performance 3D printing.
  • Color & form
    XYZprinting's vividly colored filament is engineered and tested to make sure that there is no distortion in the color and form of the filament.
  • Easy to replace filament
    The XYZprinting filament has been designed to be easy to install and replace. The da Vinci will also notify you when the filament is running low so you don't run out.
XYZprinting - neon yellow - ABS filament cartridge
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Printing Colour
Neon yellow
Compatible with
Da Vinci 1.0, 1.0 Aio
Shipping Weight
1.25 kg
Consumable
Consumable Type
Filament Diameter
1.75 mm
600 g
Printing Technology
FDM
Neon yellow
Nozzle Temperature
210 °C
Glass Transition Temperature
70 °C
Included Qty
1-pack
Compatible with
XYZprinting da Vinci 1.0, 1.0 Aio
