Xiaomi Redmi Note 11 Twilight Blue 4+ 128GB
Quicklinx: GQSHWS00 Mfr#: MZB0AO6EN
  • microSDHC
  • microSD
  • Android
£161.20 ex VAT
£193.44 inc VAT
Marketing description is not available.
  • Design so good, you just can't get enough of it
    Taking perfection a notch higher with the stunning EVOL. Design.
  • 90Hz FHD+ AMOLED Display
    Display so fine, it will blow your mind. Brace yourself for an 11 on 10 viewing experience on the splendid AMOLED Display.
  • 90Hz Refresh Rate - irresistibly smooth
    High Refresh Rate of 90Hz means smoother scrolling and graphics resulting in outstanding user experience.
  • Sunlight Display
    Designed to adjust your screen brightness according to the sunlight.
  • Reading Mode 3.0
    Designed for eye comfort.
  • Qualcomm Snapdragon 680 - efficiency has a new name
    Built on 6nm architecture, it is designed to give you superior performance while conserving power. Get ready for 11 on 10 experience!
  • Massive 5000mAh Battery 33W Pro Fast Charging - juice up in no time
    With 33W Pro Fast Charging and 5000mAh Battery, get ultra-long battery life and improved charging efficiency.
  • Turn up the cool quotient
    Consistent peak performance with Multiple graphite sheets for heat dissipation. More effective thermal conductivity with an upgraded cooling system and multiple layers of graphite sheets.
  • Turn up the volume
    Dual stereo speakers. Immersive audio quality.
Xiaomi Redmi Note 11 - twilight blue - 4G smartphone - 128 GB - GSM
4G smartphone
Display
OLED display - 2400 x 1080 pixels - 6.43" - 409 ppi - (90 Hz) - AMOLED
Qualcomm Snapdragon 680 2.4 GHz (8-core)
Graphics Accelerator
Qualcomm ADRENO 610
RAM 4 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
Android 11 with MIUI 13
Main Camera
50 Megapixel - f/1.8 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
2 Megapixel - f/2.4 - macro camera
Fourth Camera
2 Megapixel - f/2.4 - depth camera
Front Camera
13 Megapixel f/2.4
Service Provider
Not specified
SIM Card
Dual-SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Face recognition, fingerprint reader (side)
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 2580 minutes
Protection
Dustproof, splashproof
Twilight blue
73.87 mm x 8.09 mm x 159.87 mm
179 g
0.596 W/kg (head) , 0.989 W/kg (body) , 1.996 W/kg (limb)
Smartphone
Touch
Protection
73.87 mm
8.09 mm
159.87 mm
179 g
Body Colour
Twilight blue
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Android 11
User Interface
MIUI 13
Navigation
GPS, GLONASS, BeiDou, Galileo
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 20, Band 28, Band 32, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.0
Phone Features
Sensors
Accelerometer, ambient light sensor, proximity sensor, digital compass, gyroscope
Security Devices
Security Technology
AI face unlock
Additional Features
Z-axis linear vibration motor, dual stereo speakers, IR blaster, write booster
Media Player
Sound Enhancements
Hi-Res audio certified
Clock Speed
2.4 GHz
Processor Core Qty
8-core
Graphics System
Qualcomm ADRENO 610
RAM
LPDDR4X SDRAM - 4 GB
Internal Memory Capacity
128 GB
Memory Interface
UFS 2.2
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.4
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
Main Camera
Sensor Resolution
50 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Light Source
LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 3840 x 2160 (4K) at 30 fps
AI Quad camera
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Field of View (FoV)
118 degree(s)
Third Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Fourth Camera
Sensor Resolution
2 Megapixel
Lens Aperture
F/2.4
Functions
Depth camera
Display
OLED display
AMOLED
Diagonal Size
6.43"
Display Resolution
2400 x 1080 pixels
Display Format
Full HD+
Pixel Density
409 ppi
Max Brightness
1000 cd/m²
Enhancement Technology
Sunlight mode, Reading mode 3.0
Refresh Rate
90 Hz
Touch Sampling Rate
180 Hz
Contrast Ratio
4500000:1
DCI-P3 Wide colour gamut, Dot Display
Connector Type
USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
5000 mAh
Fast Charging Technology
Pro fast charging
Talk Time
2580 minutes
Run Time Details
Talk: up to 2580 min , Playback (video): up to 22 hrs , Playback (audio): up to 215 hrs
IP53, TUV SUD, SGS, IEC 60529
Power adapter, SIM card removal tool, USB-C cable, protective case
