Xiaomi Redmi 10 Pebble White 4GB RAM 64GB ROM
Quicklinx: GKCZWS00 Mfr#: MZB09PCEN
  • microSDHC
  • microSD
  • Android
Redmi Note 10 is equipped with an advanced linear motor, which intelligently converts various sounds and movements into precise vibration effects, enhancing your gaming and overall usage experience.
Equipped with an AI quad camera, which enables you to explore and capture all the scenes from your daily life in detail. Whether you are shooting vast mountain ranges, distant landmarks or close-up shots, they can all be captured with ease
The body has a curved back, flattened ends and tapered edges to offer a refined, premium appearance
The natural color scheme emphasizes premium simplicity. With its glossy finish, the color can complement your style
The frame makes the phone look even slimmer than it is. With a weight of less than 180g, carrying the phone around is effortless
The redesigned Arc side fingerprint sensor is seamlessly integrated into the body for a comfortable hand feel. Let fast unlocking becomes a habit
Storage 64GB
Ram 4GB
Dimensions Height: 160.46mm, Width: 74.5mm, Thickness: 8.29mm, Weight: 178.8g
Display 6.43" Amoled DotDisplay
Resolution: 2400x1080
409 PPI
Contrast ratio: 4,500,000:1
Brightness: HBM 700 nits (typ), 1100 nits peak brightness (typ)
DCI-P3 color gamut
8-bit color
Reading mode 3.0
Sunlight display 2.0
Low blue light certified by SGS
Processor Qualcomm Sanpdragon 678
Rear Camera 48MP, 8MP, 2MP, 2MP
Front Camera 13MP
Fingerprint Sensor and AI face unlock
  • Always camera-ready
    With the AI quad camera, you are well-equipped for any photo scenario.
  • Get creative with short videos
    Use filters to take your short videos to the next level.
  • Smoother scrolling
    You can enjoy a smoother, more fluid viewing experience when scrolling or playing games.
  • Speakers that impress
    Enjoy a better audio with dual speakers. Listen to music with crisp stereo sound directly from your phone.
  • Power that lasts
    The large battery has enough power to easily get you through the day.
