Always camera-ready
With the AI quad camera, you are well-equipped for any photo scenario. -
Get creative with short videos
Use filters to take your short videos to the next level. -
Smoother scrolling
You can enjoy a smoother, more fluid viewing experience when scrolling or playing games. -
Speakers that impress
Enjoy a better audio with dual speakers. Listen to music with crisp stereo sound directly from your phone. -
Power that lasts
The large battery has enough power to easily get you through the day.
- Xiaomi Redmi 10 - pebble white - 4G smartphone - 128 GB - GSM
- Product Type
- 4G smartphone
- Display
- 2400 x 1080 pixels - 6.5" - 405 ppi - (90 Hz) - Corning Gorilla Glass 3 (scratch resistant glass)
- FM radio
- Processor
- MediaTek Helio G88 2 GHz (8-core)
- Graphics Accelerator
- ARM Mali-G52
- Memory
- RAM 4 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 512 GB
- Operating System
- Android 11 with MIUI 12.5
- Main Camera
- 50 Megapixel - f/1.8 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Fourth Camera
- 2 Megapixel - f/2.4 - depth camera
- Front Camera
- 8 Megapixel f/2.0 - focus free
- Service Provider
- Not specified
- SIM Card
- Dual-SIM
- Wireless Interface
- Wi-Fi, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1800 minutes
- Pebble white
- 75.53 mm x 8.92 mm x 161.95 mm
- 181 g
- SAR
- 0.586 W/kg (head), 1.992 W/kg (limb), 0.978 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Integrated Components
- FM radio
- 75.53 mm
- 8.92 mm
- 161.95 mm
- 181 g
- Body Colour
- Pebble white
- SAR Value
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Android 11
- User Interface
- MIUI 12.5
- Navigation
- GPS, A-GPS, GLONASS, BeiDou, Galileo
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- Wi-Fi, Bluetooth 5.1
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass
- Security Devices
- Security Technology
- AI face unlock
- Android Enterprise Recommended
- Additional Features
- Fast Charging, dual stereo speakers, IR blaster, 9W reverse wired charging
- Clock Speed
- 2 GHz
- Processor Core Qty
- 8-core
Graphics System
- ARM Mali-G52
- RAM
- LPDDR4X SDRAM - 4 GB
- Internal Memory Capacity
- 128 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 512 GB
Front Camera
- Sensor Resolution
- 8 Megapixel
- Lens Aperture
- F/2.0
- Focus Adjustment
- Focus free
- Camera Modes
- Panoramic selfies
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
Main Camera
- Sensor Resolution
- 50 Megapixel
- Lens Aperture
- F/1.8
- Focus Adjustment
- Automatic
- Light Source
- Flash
- Video Resolutions
- AI Quad camera
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 120 degree(s)
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Fourth Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Depth camera
Display
- Diagonal Size
- 6.5"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 405 ppi
- Enhancement Technology
- Sunlight mode
- Refresh Rate
- 90 Hz
- Protection
- Dot Display, Reading mode 3, AdaptiveSync technology
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Talk Time
- 1800 minutes
- Run Time Details
- Talk: up to 1800 min , Playback (video): up to 14 hrs , Playback (Music): up to 158 hrs
- Included Accessories
- Protective cover, SIM card removal tool, USB-C cable, 22.5W power adapter
- Limited warranty - 2 years
