The Xerox WorkCenter 6655V XM Color Multifunction Printer, enabled by Xerox ConnectKey technology, is built for the way you want to work. From cost control and energy savings, to cloud-based scanning solutions and data security, the WorkCenter 6655V XM offers small and medium businesses access to the same solutions typically reserved for larger enterprises.
The cost of doing business is a lot less when you invest in the right technology
The Xerox WorkCenter 6655V XM, enabled by ConnectKey, features special tools that simplify the way you manage printing and enable more ways to keep costs in check. -
Business data is your company's most valuable asset
The Xerox WorkCenter 6655V XM, enabled by ConnectKey, guards your data with a comprehensive range of features, technologies and solutions from the highly trusted security industry leaders. -
Powerful partnerships
The Xerox ConnectKey MFPs also include a built-in McAfee technology agent, resulting in the industry's first lineup of multifunction printers that protect themselves from potential outside threats. McAfee's whitelisting technology ensures only safe, pre-approved files or functions are executed on your devices, eliminating the need to manually update software levels against security threats. -
Don't just keep up; get ahead
With Xerox ConnectKey technology, the WorkCenter 6655V XM color laser multifunction printer sets a benchmark for office efficiency. Automate everything from routine tasks to complex workflows. Plus, impressive color output gives your important documents added impact. -
Print around
Automatically skips jobs waiting for additional resources (such as special paper size) and prints the next job in the queue. -
High-resolution output; high-impact documents
Up to 2400 x 600 dpi print resolution produces vibrant, attention-grabbing color images and crisp text. -
Customize your workflows
Built on the Xerox EIP platform, Xerox Workflow Solutions let you install productivity-enhancing software directly on the device for fast, easy access via the color touch screen interface. -
Color touchscreen
Color touchscreen user interface features the look, feel and bright, intuitive icons you've become accustomed to with Xerox technology. Easily access all major functions directly from the home screen. -
A help desk at your fingertips
Get quick, easy, step-by-step troubleshooting assistance - like tips for sending a scan via email - with embedded help videos right on the user interface.
- Xerox 6655V_XM - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 10000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi, 200 x 100 dpi, 600 x 600 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- 139.7 x 139.7 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets, books
- Document Feeder Capacity
- 60 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper
- Standard Media Capacity
- 1250 sheets
- Max Media Capacity
- 1250 sheets
- Bypass Feeder Capacity
- 150 sheets
- Output Trays Capacity
- 250 sheets
- Stapler
- Included
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 53.8 cm x 55.3 cm x 62.5 cm
- 37.6 kg
- Pricing Type
- Metered Printer Supplies Replenishment
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 100000 pages
- 10000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 4 GB
- Hard Disk Drive
- 250 GB
Copying
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 9999
- Copying Features
- Auto paper select, auto tray switching, booklet creation, ID Card Copy, collation copy, Edge Erase
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF, XPS
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Automatic redialing, auto reduction, delayed sending, fax polling, fax activity reports, Duplex Fax
Document & Media Handling
- Min Original Size
- 139.7 x 139.7 mm
- Max Original Size
- Original Type
- Sheets, books
- 60 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm, 216 x 356 mm
- 1250 sheets
- 1250 sheets
- 150 sheets
- 250 sheets
- ADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 2 x input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m²
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Scanning: up to 51 ipm - B/W , Scanning: up to 24 ipm - B/W duplex , Scanning: up to 28 ipm - colour , Scanning: up to 13 ipm - colour duplex
Finishing Equipment
- Stapler
- Included
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL
- Operating System Support
- MS Windows XP SP3, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.10 x64, openSUSE 13.1 x64
- Voltage Required
- 486.36 Watt
- Power Consumption Standby
- 71.04 Watt
- Power Consumption Sleep
- 2.71 Watt
- First Copy Out Time B/W
- 15 sec
- First Copy Out Time Colour
- 16 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 3000 pages , 1 x toner cartridge (yellow) - up to 3000 pages
- GS, NOM, Directive 1999/5/EC, FCC Part 68, RoHS, UL 60950-1, FCC Part 15 A, FDA, Directive 2004/108/EC, Directive 2006/95/EC, CSA C22.2 No. 60950-1-07 Second Edition, Directive 2011/65/EC, EAC, WEEE 2002/96/EC, CDRH Class 1
- Pricing Type
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site
- 53.8 cm
- 55.3 cm
- 62.5 cm
- 37.6 kg
- Shipping Width
- 67.1 cm
- Shipping Depth
- 67.5 cm
- Shipping Height
- 75.1 cm
- Shipping Weight
- 43.9 kg
- Sound Emission
- 25.1 dBA (idle) / 51.8 dBA (operating)
- 5 °C
- 32 °C
- 15 - 85%
