Your basket is empty
Xerox WorkCentre 6655V_X Colour Laser Multifunction Printer
Quicklinx: 9XBHWS00 Mfr#: 6655V_X?GB
The Xerox® WorkCentre™ 6655 Colour Multifunction Printer, enabled by Xerox ConnectKey® Technology, is built for the way you want to work. From cost control and energy savings, to cloud-based scanning solutions and data security, the WorkCentre 6655 offers small and medium businesses access to the same solutions typically reserved for larger enterprises.
Cost Control and Energy Savings
The cost of doing business is a lot less when you invest in the right technology. The Xerox® WorkCentre™ 6655, enabled by ConnectKey®, features innovative tools that simplify the way you manage printing and enable more ways to keep costs in check.
- User Permissions allow the ability to restrict access to print features by user, group, time of day, and by application. For example, all Microsoft Outlook emails may be set to print automatically in black and white while all PowerPoint presentations may print in colour.
- Customize your print driver settings for economy and efficiency. For example, choose N-up for printing multiple pages on a single sheet as your default.
- By default, our print driver is set to two-sided printing, and the Earth Smart feature allows you to select other default settings that encourage responsible usage.
Xerox® Standard Accounting provides reports for greater cost control of all device functions. Advanced solutions from Xerox® Business Innovation Partners deliver even more helpful tools for larger office environments.
The WorkCentre 6655 scanner uses LED lighting, which consumes 1/3 the power of traditional scanners that use fluorescent lamps.
With Cisco EnergyWise, enabled by Xerox Power Management Information Base (MIB), you can control, manage and report your device’s power consumption information, and set optimal power states and timeout intervals.
Security
Business data is your company’s most valuable asset. The Xerox® WorkCentre™ 6655, enabled by ConnectKey®, guards your data with a comprehensive range of features, technologies and solutions from the most trusted security industry leaders.
We realize not everyone understands security, so along with the many standard security features, the Xerox ConnectKey MFPs also include a built-in McAfee® technology agent, resulting in the industry’s first lineup of multifunction printers that protect themselves from potential outside threats. McAfee's whitelisting technology ensures only safe, pre-approved files or functions are executed on your devices, eliminating the need to manually update software levels against new security threats.
Plus, automatic Cisco® TrustSec integration provides comprehensive visibility into which people and what devices are connecting across the entire network infrastructure. Cisco TrustSec also enables an exceptional level of control over where those with proper permission can go and what they can access.
- Safeguard all sensitive data with encrypted PDF files for scanning; complete hard drive encryption, compliant with the 256-bit AES FIPS 140-2 standard; and Image Overwrite with a 3-pass scrub process to ensure total deletion of all data fragments.
- Permit only authorized users to access the device with Xerox user permissions, network authentication, IP filtering, and smart card, role-based and function-level login.
- As new threats emerge, Xerox proactively monitors security clearinghouses for new vulnerabilities and provides patches when necessary, ensuring your equipment stays current and your data is kept safe.
- The WorkCentre 6655 colour laser multifunction printer complies with the latest security standards across industries, including government, finance and healthcare. These include Common Criteria, HIPAA, Data Protection Act, COBIT and more. These devices can conform to any standard, with controls available to match your needs.
- Prevent IP theft and ensure non-repudiation by having total visibility into the device and network. With security policy management and tracking of all activity on the device, you can know who accessed what, when and details of every interaction with the device.
Productivity
- With Xerox® ConnectKey® technology, the WorkCentre™ 6655 colour laser multifunction printer sets a new benchmark for office efficiency. Automate everything from routine tasks to complex workflows. Plus, impressive colour output gives your important documents added impact.
- Get your print and copy jobs out as fast as 35 ppm – with first-page-time out time as fast as 11 seconds.
- Automatically skips jobs waiting for additional resources (such as special paper size) and prints the next job in the queue.
- Up to 2400 x 600 dpi print resolution produces vibrant, attention-grabbing colour images and crisp text.
- Built on the Xerox EIP platform, Xerox Workflow Solutions let you install productivity-enhancing software directly on the device for fast, easy access via the colour touch screen interface.
- Scan and create multiple, single-page PDFs that can be distributed to different repositories for large, transactional processing. Also, create a multi-page, single PDF for easier storing and emailing of documents.
- Use the Single Touch Scan feature to create a dedicated, easy-to-locate scan button directly on the colour touch screen interface. Assign the Single Touch Scan button its own scanning workflow for fast document distribution and archiving.
- Save favorite addresses for faster document routing via all device services. Users can pre-define fax, email, scan and internet fax locations for easy access in one centralized place. They can edit or add contacts, if they have permissions, at any time from the user interface. Playing on how users want to use information today, our MFP can save “Favorites” for all services.
- Remotely and securely operate the WorkCentre 6655 control panel from any office PC as though you were standing at the device. The Remote Control Panel makes it easier and more convenient to troubleshoot and to train users, and for IT staff to remotely view and monitor the user interface. And during a remote session, walk-up users are notified at the device to prevent simultaneous system changes. Plus, advanced print drivers and free device management tools let you remotely monitor real-time performance and available resources for greater uptime.
Convenience
- The Xerox® WorkCentre™ 6655, enabled by ConnectKey®, gives you room to roam with easy mobile accessibility for wherever your work takes you. And when you’re in the office, convenient tools make your interaction with the WorkCentre 6655 quick and easy.
- Colour touch-screen user interface features the look, feel and bright, intuitive icons you’ve become accustomed to with Xerox technology. Easily access all major functions directly from the home screen.
- Get quick, easy, step-by-step troubleshooting assistance — like tips for sending a scan via email — with embedded help videos right on the user interface.
- The convenience stapler makes quick work of stapling up to 20 sheets of 20 lb. bond / 75 gsm paper.
- Take the mystery and anxiety out of wireless and mobile device printing when you purchase our software. Xerox has all the options to enable secure, accurate printing from any Apple iOS or Android mobile device, to any printer or multifunction printer, regardless of brand. Get industry-leading accuracy when printing native PowerPoint, Word and other standard files. Plus, Xerox offers IT-friendly optional capabilities such as PIN code access, multiple mobile operating systems and more.
- Print email, photos and important office documents directly from your Apple iOS and OS X devices with no software to download, no drivers to install, and no cables to connect. With AirPrint, your Apple device automatically locates and connects to the WorkCentre 6655 multifunction laser printer over your office’s wired or Wi-Fi network.
- Xerox ConnectKey Share to Cloud provides organizations with powerful document scanning capabilities that connect Xerox multifunction printers to popular cloud services and email. It delivers all of the benefits of cloud computing in the same way that apps leverage the cloud on mobile devices. Scan a document using the touch screen on your multifunction printer, and the ConnectKey Share to Cloud solution converts the file and distributes it to your selected cloud service.
- Mopria certification simplifies the mobile printing experience for tablets and smartphones to many printing devices, including the WorkCentre 6655 Colour Multifunction Printer.
Xerox WorkCentre 6655V_X - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( colour )
Monthly Duty Cycle (max)
100000 pages
Recommended Monthly Volume
10000 pages
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi, 600 x 600 dpi
Scanning
600 x 600 dpi
Original Size
139.7 x 139.7 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
60 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper
Standard Media Capacity
700 sheets
Max Media Capacity
1250 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
250 sheets
Stapler
Included
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
AC 230 V ( 50/60Hz )
53.8 cm x 55.3 cm x 62.5 cm
37.6 kg
Environmental Standards
ENERGY STAR Qualified , Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
100000 pages
10000 pages
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
4 GB
Hard Disk Drive
250 GB
Copying
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Auto paper select, auto tray switching, booklet creation, ID Card Copy, collation copy, Edge Erase
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
11 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Speed Dialing
200 station(s)
Automatic redialing, auto reduction, delayed sending, fax polling, fax activity reports, Duplex Fax
Document & Media Handling
Min Original Size
139.7 x 139.7 mm
Max Original Size
Original Type
Sheets, books
60 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm, 216 x 356 mm
700 sheets
Max Media Capacity
1250 sheets
150 sheets
250 sheets
ADF - 60 sheets size: 139.7 x 139.7 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 2 x input tray - 550 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m²
Speed Details
Printing: up to 35 ppm ( A4 ) - B/W , Printing: up to 35 ppm ( A4 ) - colour , Scanning: up to 51 ipm - B/W , Scanning: up to 24 ipm - B/W duplex , Scanning: up to 28 ipm - colour , Scanning: up to 13 ipm - colour duplex
Finishing Equipment
Stapler
Included
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL
Operating System Support
MS Windows XP SP3, MS Windows Vista SP2, MS Windows Server 2008 R2, Apple Mac OS X 10.7, MS Windows Vista SP2 64-bit Edition, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows XP 64-bit Edition SP3 or later, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Fedora 19, MS Windows 7 (32/64 bits), Ubuntu Linux 13.10 x64, openSUSE 13.1 x64
486.36 Watt
Power Consumption Standby
71.04 Watt
Power Consumption Sleep
2.71 Watt
First Copy Out Time B/W
15 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x Cartridge ( black ) - up to 6000 pages , 1 x Cartridge ( magenta ) - up to 3000 pages , 1 x Cartridge ( cyan ) - up to 3000 pages , 1 x Cartridge ( yellow ) - up to 3000 pages
GS, NOM, Directive 1999/5/EC, FCC Part 68, RoHS, UL 60950-1, FCC Part 15 A, FDA, Directive 2004/108/EC, Directive 2006/95/EC, CSA C22.2 No. 60950-1-07 Second Edition, Directive 2011/65/EC, EAC, WEEE 2002/96/EC, CDRH Class 1
Blue Angel Compliant
Limited warranty - 1 year - on-site
53.8 cm
55.3 cm
62.5 cm
37.6 kg
Shipping Width
67.1 cm
Shipping Depth
67.5 cm
Shipping Height
75.1 cm
Shipping Weight
43.9 kg
Sound Emission
25.1 dBA (idle) / 51.8 dBA (operating)
5 °C
32 °C
15 - 85%
