The Xerox WorkCentre 3225 consolidates five key office functions – print, copy, scan, fax and email -- into one easy-to-use multifunction laser printer. Automatic two-sided printing and built-in Wi-Fi offer individual users and small work teams powerful tools at an affordable price.
Budget friendly
Keep your costs down with fast, reliable printing for a single user or small team. -
Count on it
Keep intervention to a minimum with long-lasting, easy-to-replace cartridges and reliable operation that handles every job with ease. -
Print efficiently
Split supplies mean you replace only what you use - so you get the most out of every print cartridge. -
Quick printing
A print speed of up to 28 ppm and a rapid first page-out time as fast as 8.5 seconds enable you to spend less time at the device and more time focusing on your business. -
Save more than money
Standard, automatic two-sided printing saves valuable time and paper. Power Save and Toner Save modes, and the Earth Smart print driver, let you choose to spend less on electricity and consumables. -
Powerful and productive
The standard 256 MB of memory and the 600 MHz processor ensure jobs print quickly and accurately, even when loaded with graphics. -
Visual impact
Printing at 4800 x 600 dpi enhanced image quality, together with PCL and PostScript emulations, ensures consistently clear text and sharp graphics. -
Completely secure
A wide array of features ensures that private data remains secure, including SNMPv3 and IPv6 network security protocols, and Secure Fax Receive, which holds a fax until an authorized user logs in to retrieve it. -
So many choices
Comprehensive copy features include reduce/enlarge, auto background suppression, 3-level darkness control, collation, ID card copy and N-up layouts. -
Simplicity
Position the multifunction printer anywhere it's convenient; the Xerox Easy Wireless Setup helps you connect quickly and easily to your Wi-Fi network. -
Wi-Fi Direct
The WorkCentre 3225 multifunction printer can communicate with Wi-Fi-enabled devices without needing an existing wireless network. Wi-Fi Direct enables mobile phones, tablets and laptop computers to make a secure wireless connection directly to the printer. -
Easy to reach
With quiet operation, built-in wireless networking and a compact design, the WorkCentre 3225 fits exactly where you need it to be most productive. -
Color and black-and-white scanning
It quickly converts paper into electronic documents, ready to be saved to a network, desktop folder or inserted into an application. -
Intuitive UI
The user-friendly front panel helps you find your most-used functions fast with easy-to-read buttons and two-line LCD display. -
Scan to email
This function enables sending paper documents directly to email recipients from the front panel - no need to walk back and forth from the multifunction printer to your computer. -
The 40-sheet Automatic Document Feeder
This feature saves time copying and scanning multiple-page documents.
- Xerox WorkCentre 3225V_DNI - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 30000 pages
- Max Copying Resolution
- Up to 1200 x 1200 dpi
- Max Printing Speed
- Up to 29 ppm
- Max Printing Resolution
- Up to 4800 x 600 dpi
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Scanning
- 600 x 600 dpi
- Original Size
- 148 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thick paper, card stock
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 120 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder
- Power
- AC 230 V (50/60Hz)
- 40.1 cm x 36.2 cm x 36.5 cm
- 11.4 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 30000 pages
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
Copying
Printing
- Up to 29 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
Fax Machine
Fax Machine Features
- Fax forwarding, automatic redialing, colour faxing, auto reduction, junk fax filter, secure receive
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 250 sheets
- 1 sheet
- 120 sheets
- ADF - 40 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 120 sheets
- Speed Details
- Printing: up to 29 ppm (Letter A) - B/W , Printing: up to 28 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x LAN
- LDAP, SSL, WPA2, IPsec, 802.1x, MAC address filtering, WPA2-Enterprise
- Operating System Support
- HP-UX 11i v3, SunSoft Solaris x86 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, HP-UX 11.0, HP-UX 11i v2, SunSoft Solaris x86 10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Debian Linux 5.0, Red Hat Enterprise Linux 5, HP-UX 11i v1, Red Hat Enterprise Linux 6, Fedora 15, MS Windows Server 2008 R2 x64 Edition, SunSoft Solaris x86 11, MS Windows Server 2012, Windows 8, SunSoft Solaris SPARC Platform Edition 9, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Windows 8 64-bit, Fedora 16, Fedora 17, Fedora 18, openSUSE 12.3, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, IBM AIX 5.1 - 7.1, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.1, Linux Mint 15
- Software Included
- Nuance Image Retriever, Nuance PaperPort
- Voltage Required
- 417 Watt
- Power Consumption Standby
- 46 Watt
- Power Consumption Sleep
- 2 Watt
- Warm-Up Time
- 14 sec
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages , 1 x drum - up to 10000 pages
- GS, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, FDA, EN 60825-1, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC, Directive 2012/19/EU, Directive 2011/65/EU
- ENERGY STAR Certified
- Blue Angel Compliant
- 40.1 cm
- 36.2 cm
- 36.5 cm
- 11.4 kg
- Sound Emission
- 26 dBA (idle) / 53 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
