Xerox WorkCentre 3225V_DNI Mono LED Laser Multi-Function Printer
Quicklinx: 9X6ZWS00 Mfr#: 3225V_DNI
The Xerox WorkCentre 3225 consolidates five key office functions – print, copy, scan, fax and email -- into one easy-to-use multifunction laser printer. Automatic two-sided printing and built-in Wi-Fi offer individual users and small work teams powerful tools at an affordable price.
  • Budget friendly
    Keep your costs down with fast, reliable printing for a single user or small team.
  • Count on it
    Keep intervention to a minimum with long-lasting, easy-to-replace cartridges and reliable operation that handles every job with ease.
  • Print efficiently
    Split supplies mean you replace only what you use - so you get the most out of every print cartridge.
  • Quick printing
    A print speed of up to 28 ppm and a rapid first page-out time as fast as 8.5 seconds enable you to spend less time at the device and more time focusing on your business.
  • Save more than money
    Standard, automatic two-sided printing saves valuable time and paper. Power Save and Toner Save modes, and the Earth Smart print driver, let you choose to spend less on electricity and consumables.
  • Powerful and productive
    The standard 256 MB of memory and the 600 MHz processor ensure jobs print quickly and accurately, even when loaded with graphics.
  • Visual impact
    Printing at 4800 x 600 dpi enhanced image quality, together with PCL and PostScript emulations, ensures consistently clear text and sharp graphics.
  • Completely secure
    A wide array of features ensures that private data remains secure, including SNMPv3 and IPv6 network security protocols, and Secure Fax Receive, which holds a fax until an authorized user logs in to retrieve it.
  • So many choices
    Comprehensive copy features include reduce/enlarge, auto background suppression, 3-level darkness control, collation, ID card copy and N-up layouts.
  • Simplicity
    Position the multifunction printer anywhere it's convenient; the Xerox Easy Wireless Setup helps you connect quickly and easily to your Wi-Fi network.
  • Wi-Fi Direct
    The WorkCentre 3225 multifunction printer can communicate with Wi-Fi-enabled devices without needing an existing wireless network. Wi-Fi Direct enables mobile phones, tablets and laptop computers to make a secure wireless connection directly to the printer.
  • Easy to reach
    With quiet operation, built-in wireless networking and a compact design, the WorkCentre 3225 fits exactly where you need it to be most productive.
  • Color and black-and-white scanning
    It quickly converts paper into electronic documents, ready to be saved to a network, desktop folder or inserted into an application.
  • Intuitive UI
    The user-friendly front panel helps you find your most-used functions fast with easy-to-read buttons and two-line LCD display.
  • Scan to email
    This function enables sending paper documents directly to email recipients from the front panel - no need to walk back and forth from the multifunction printer to your computer.
  • The 40-sheet Automatic Document Feeder
    This feature saves time copying and scanning multiple-page documents.
Xerox WorkCentre 3225V_DNI - multifunction printer - B/W
Multifunction printer
Fax Type
Plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
30000 pages
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 29 ppm
Max Printing Resolution
Up to 4800 x 600 dpi
Data Compression System
MH, MR, MMR, JBIG, JPEG
Scanning
600 x 600 dpi
Original Size
148 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thick paper, card stock
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
40.1 cm x 36.2 cm x 36.5 cm
11.4 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
30000 pages
AirPrint Enabled
Standard Memory
256 MB
Copying
Printing
Max Printing Speed
Up to 29 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Fax Machine Features
Fax forwarding, automatic redialing, colour faxing, auto reduction, junk fax filter, secure receive
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
250 sheets
1 sheet
120 sheets
ADF - 40 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 29 ppm (Letter A) - B/W , Printing: up to 28 ppm (A4) - B/W
1 x USB 2.0 , 1 x LAN
Security Protocols & Features
LDAP, SSL, WPA2, IPsec, 802.1x, MAC address filtering, WPA2-Enterprise
Operating System Support
HP-UX 11i v3, SunSoft Solaris x86 9, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, HP-UX 11.0, HP-UX 11i v2, SunSoft Solaris x86 10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 11, Fedora 12, Fedora 13, Fedora 14, Debian Linux 5.0, Red Hat Enterprise Linux 5, HP-UX 11i v1, Red Hat Enterprise Linux 6, Fedora 15, MS Windows Server 2008 R2 x64 Edition, SunSoft Solaris x86 11, MS Windows Server 2012, Windows 8, SunSoft Solaris SPARC Platform Edition 9, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Windows 8 64-bit, Fedora 16, Fedora 17, Fedora 18, openSUSE 12.3, Linux Mint 13, Linux Mint 14, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.5 - 10.9, IBM AIX 5.1 - 7.1, Fedora 19, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Ubuntu Linux 13.04, Debian Linux 7.1, Linux Mint 15
Software Included
Nuance Image Retriever, Nuance PaperPort
AC 230 V (50/60Hz)
417 Watt
Power Consumption Standby
46 Watt
Power Consumption Sleep
2 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
10 sec
Consumables Included
1 x toner cartridge (black) - up to 1500 pages , 1 x drum - up to 10000 pages
GS, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-07, WEEE, FDA, EN 60825-1, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC, Directive 2012/19/EU, Directive 2011/65/EU
ENERGY STAR Certified
Blue Angel Compliant
40.1 cm
36.2 cm
36.5 cm
11.4 kg
Sound Emission
26 dBA (idle) / 53 dBA (operating)
10 °C
32 °C
20 - 80%
9X6Z C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
