The VersaLink C400 and C405 revolutionise workplace productivity with next generation features and easy, instant cloud and mobile connectivity. Built for the way you work today, and ready for where you grow tomorrow – with all the flexibility and versatility your business needs to work better with minimal IT support and maximum security.
Powerful performance and peace of mind.
Right out of the box, you’ll count on your VersaLink C400 or C405 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you’re ready to go – hassle free. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview1, and do more with scanned documents with built-in optical character recognition (OCR)1. When it comes to safeguarding critical documents and data, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. With the VersaLink C400 and C405, you can be confident that your documents will look their best – making you look your best – giving you the confidence you need when presenting to your customers.
Easy, efficient and entirely new.
With the customisable, capacitive 5-inch colour touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox® ConnectKey® Apps help optimise office efficiency, and on-screen access to the extensive Xerox® App Gallery provides expanded functionality – like the
Xerox® Easy Translator Service app1, which quickly translates scanned documents into numerous languages. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy ccess to task-specific presets and commonly used apps on a personalised home screen.
Freedom, and appbased functionality.
The VersaLink C400 Colour Printer and VersaLink C405 Colour Multifunction Printer gives you the freedom to work where and how you want – with out-of-the-box direct connectivity to Google Drive™, Microsoft® OneDrive® and DropBox™, and access to additional options through the Xerox® App Gallery. The ability to connect and print from multiple devices is key for today’s worker, and VersaLink devices meet the challenge with optional Wi-Fi and Wi-Fi Direct, plus Apple® AirPrint®, Google Cloud Print™, Xerox® Print Service Plug-in for Android™, Near Field Communication (NFC) Tap-to-Pair and Mopria®.
*1 VersaLink C405 only.
Right out of the box, you'll count on your VersaLink C400 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you're ready to go - hassle free. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. When it comes to safeguarding critical documents and data, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. -
Easy and efficient
With the customizable touchscreen you can tap, swipe and pinch your way through tasks and functions with mobilelike ease. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy access to taskspecific presets and commonly used apps on a personalized home screen. -
Freedom, and app-based functionality
The VersaLink C400 Color Multifunction Printer gives you the freedom to work where and how you want - with out-of-the-box direct connectivity to Google Drive, Microsoft OneDrive and DropBox, and access to additional options through the Xerox App Gallery.
- Xerox VersaLink C400V/DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 26 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 36 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 36 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm) , Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - Legal (216 x 356 mm) , Up to 30 ppm - B/W - Legal (216 x 356 mm) , Up to 24 ppm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 23 ppm - colour duplex - A4 (210 x 297 mm) , Up to 23 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 21 ppm - colour duplex - Legal (216 x 356 mm) , Up to 21 ppm - B/W duplex - Legal (216 x 356 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, NFC, USB 3.0
- AirPrint Enabled
- Processor
- 1.05 GHz
- RAM Installed (Max)
- 2 GB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, HP GL, PDF, XPS, TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, photo paper, bond paper, recycled paper, card stock, punched paper, preprinted paper
- Total Media Capacity
- 700 sheets
- Media Handling
- 150-sheet bypass tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 5000 pages
- Networking
- Print server
- Printer Features
- 256-bit encryption
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Red Hat Enterprise Linux, Microsoft Windows Server 2008 R2, HP-UX 11i v3, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11, Oracle Solaris 11.3, Apple MacOS X 10.12, IBM AIX 7.2, Red Hat Fedora Core 24, SUSE Linux 13.2
- 49.1 cm x 48.8 cm x 39.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Touch screen
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
- Fonts Included
- 144 x PostScript , 82 x PCL
- Printer Features
- Media Handling
- Processor
- 1.05 GHz
RAM
- 2 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 700 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 1250 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 80000 pages
- 5000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS
- LDAP, Secure Print, Apple Bonjour, TLS, IP filtering
- Connections
- 1 x USB 3.0 , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 2000 pages , 1 x toner cartridge (magenta) - up to 2000 pages , 1 x toner cartridge (yellow) - up to 3000 pages
- JPEG graphics support
- FIPS 140-2
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 705 Watt
- Power Consumption Stand by
- 76 Watt
- Power Consumption Sleep
- 4 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 32 °C
- 10 - 85%
- Sound Emission (Idle)
- 29.2 dBA
- Sound Emission (Operating)
- 53.1 dBA
- 49.1 cm
- 48.8 cm
- 39.9 cm
- 26 kg
- Width (Shipping)
- 62.7 cm
- Depth (Shipping)
- 63.8 cm
- Height (Shipping)
- 52.6 cm
- Weight (Shipping)
- 30.45 kg
