For a black-and-white printer or multifunction printer, the VersaLink B605 is anything but basic. In fact, VersaLink sets a standard for what you can expect in workgroup productivity from Xerox. Home or away, this highly configurable, cloud-connected workplace assistant delivers amazing capabilities that go far beyond the competition - at a competitive price.
Easy, smart and secure
Right out of the box, you'll count on your VersaLink B605 to consistently and flawlessly perform the tasks that make your business work more efficiently. Completely re-engineered for superior reliability, the VersaLink B605 features an advanced hardware design with fewer moving parts, strengthened paper-path components, and a more advanced print head. -
Customizable, app-based functionality
With the customizable, capacitive color touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease.
- Xerox VersaLink B605V_S (B/W)
- Printing Technology
- LED (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, card stock, punched paper, preprinted paper
- Bypass Feeder Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- PC Connection Availability
- PC Connection
- Gigabit LAN, USB host, NFC, USB 3.0
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- Environmental Standards
- ENERGY STAR Qualified
- LED - monochrome
- Display Diagonal Size
- 7"
- Colour Support
- Display Features
- Touch screen
- PC Connection
- AirPrint Enabled
- Standard Memory
- 2 GB
- Hard Disk Drive
- 250 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF, HPGL, XPS, JPEG
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- 150 sheets
- Secure Print, SSL, TLS, Secure Fax, IP filtering, port blocking, AES-256, Secure Scan, Secure Email
- Voltage Required
- ENERGY STAR Certified
- 10 °C
- 32 °C
- 15 - 85%
