The Xerox Travel Scanner 150 is lightweight, smaller than a three hole punch and needs no AC outlet. Just connect the USB cable to your laptop, insert a document and you're scanning. And not just scanning, but scanning to popular and productive destinations such as email and Word, local/network/cloud storage or Microsoft SharePoint.
- Xerox Travel Scanner 150 - sheetfed scanner - portable - USB 2.0
- Sheetfed scanner - portable
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- RGB LED array
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 216 mm x 356 mm
- Supported Document Type
- Plain paper, business card, photo
- Document Feeder Type
- Manual
- Duty Cycle
- 165 scans per day
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- 29.7 cm x 5.1 cm x 3.8 cm
- 340 g
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- RGB LED array
- Duty Cycle
- 165 scans per day
- Scanner Speed Details
- 10 sec/scan - black & white - Letter - 200 dpi , 10 sec/scan - colour - Letter - 150 dpi
- Scanner Features
- Powered by USB port, Auto Crop, AutoLaunch Technology, Auto Straighten, auto brightness, Visioneer Acuity Technology
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Manual
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- Presto! BizCard, Nuance PaperPort, Visioneer OneTouch, Nuance OmniPage, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB
- 29.7 cm
- 5.1 cm
- 3.8 cm
- 340 g
