Xerox Phaser 7500N Colour Laser Printer
Quicklinx: 6D2RWS00 Mfr#: 7500V_N
Save big when you bring your workgroup's diverse and high-volume color printing in house. The Phaser 7500 sports plenty of features that make it a perfect fit for the office on-demand print environment.
Produce brilliant, accurate color right "out of the box". The Phaser 7500 printer delivers the tools to make you look like a color expert.
Running complex jobs doesn't have to be complicated. The Phaser 7500 offers superior printer management capabilities and innovative features that make it especially easy to use.
  • Phaser 7500
    Professional-level colour your entire office can enjoy. The Phaser 7500, our new, robust, network-ready printer will fit right in with your busy office, handling professional-quality print jobs with ease. You'll get inspired colour control features, simplified print management tools and the power to do more than ever before. All at a price that's sure to leave you smiling.
  • Quick Facts
    •Colour: up to 35 ppm • Black: up to 35 ppm • First-page-out-time: As fast as 7 seconds colour / 7 seconds black and white • Processor: 1 GHz Freescale PowerGUICC III • Network connectivity standard • Print resolution: up to 1200 x 1200 dpi • Maximum duty cycle: up to 150,000 pages/month • Maximum paper size: 320 x 1,200 mm • Minimum dimensions (w x d x h): 640 x 665 x 770 mm • What comes in the box • Colour toner cartridges (capacity: 9,600 pages each1) • Black toner cartridge (capacity: 19,800 pages1) • Power cord • Software and documentation
  • On-demand productivity
    •Fast print speeds (up to 35 ppm and first-page-out as fast 7 seconds) mean you don't have to wait, even for complex colour jobs • Built-in networking is standard so all users-Microsoft Windows, Apple Macintosh and Linux-can tap into the fast Gigabit Ethernet • Increase accountability and reduce costs with features that track and analyze colour and black-only printing, and help you accurately charge back billing for individuals or departments • Scale to fit your workgroup's space from a low-profile desktop model to a highly productive floor-standing model with three additional oversize media ready 500-sheet trays • Print in-house with Phaser 7500 instead of sending jobs out to commercial printers or quick copy shops, saving time and money
  • Quality colour you can count on
    •Up to 1200 x 1200 dpi image resolution gives you sharp, detailed prints on the Phaser 7500 • Precise colour matching with Pantone -approved colour tables and true Adobe PostScript 3 mean your prints will look exactly as you intended • Xerox Emulsion Aggregate (EA) Toner produces the smallest toner particles in the market, resulting in finer lines, higher contrast and sharper image quality. It requires less energy to manufacture and less toner per page. • Consistent output print after print is ensured thru advanced automatic colour calibration requiring no user intervention • Color By Words colour correction lets you select desired colour modifications from a simple drop-down list
  • Easy to use and manage
    •Easily manage, configure and troubleshoot the Phaser 7500 from any computer using CentreWare Internet Services network web administration tools • Easy-open access is in front so you don't need to rotate or move the Phaser 7500 to change toner or add paper • Get immediate updates on your print job status, toner supply levels and troubleshooting tips via the front panel, your desktop or the web • Store frequently printed files on the built-in hard drive (standard on 7500DX) for fast, easy, walk-up printing • Private data stays secure with Secure Print, which holds the job in the queue until a PIN is entered at the printer, and Hard Drive overwrite "shreds" data after every job or request • Built-in support for security protocols, including IPv6, 802.1x and IPSec, makes the Phaser 7500 a good network citizen 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode.
Xerox Phaser 7500N - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
66 kg
Max Media Size
320 x 1200 mm
Print Speed
Up to 35 ppm - B/W , Up to 35 ppm - colour
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
USB, Gigabit LAN
Power QUICC III 1 GHz
RAM Installed (Max)
512 MB (2 GB) - DDR2 SDRAM - SO-DIMM 200-pin
Language Simulation
PCL 5C, PostScript 3, PDF 1.4
Media Type
Envelopes, transparencies, labels, plain paper, banners, cards, cover paper, glossy paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Microsoft Windows 2000, SunSoft Solaris 8, SunSoft Solaris 9, HP-UX 11i v2, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, SunSoft Solaris 10, Red Hat Fedora Core 1, Red Hat Fedora Core 2, HP-UX 11, Red Hat Fedora Core 4, SuSE Linux 10.0, IBM AIX 5L 5.3, Red Hat Fedora Core 3, Red Hat Fedora Core 5, Red Hat Linux 4, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
Microsoft Certification
Works with Windows Vista
1-year warranty
64 cm x 66.5 cm x 39.9 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
1200 dpi
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
81 x PCL 5c , 139 x PostScript
Colour Management Features
PANTONE Digital Color
Media Handling
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Technology / Form Factor
Slots Qty
2
Empty Slots
1
Media Handling
Media Type
Max Media Size
320 x 1200 mm
Media Weight
67 g/m² - 280 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - 320 x 1200 mm weight: 67 g/m² - 280 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 67 g/m² - 256 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
400 sheets
Duty Cycle
150000 pages
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, LPR/LPD, FTP, DHCP
Remote Management Protocol
SNMP 3, IPP, HTTP, HTTPS, FTP
Security Protocols & Features
Secure Print, IPsec, 802.1x
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 19800 pages , 1 x toner cartridge (cyan) - up to 9600 pages , 1 x toner cartridge (magenta) - up to 9600 pages , 1 x toner cartridge (yellow) - up to 9600 pages
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class A certified, FCC Part 15, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-03, Section 508
Power supply - internal
Frequency Required
50/60 Hz
670 Watt
Power Consumption Stand by / Sleep
95 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 80%
Sound Emission (Operating)
51 dBA
Sound Emission (Quiet Mode)
26 dBA
64 cm
66.5 cm
39.9 cm
66 kg
Width (Shipping)
76.7 cm
Depth (Shipping)
65 cm
Height (Shipping)
78.2 cm
Weight (Shipping)
83.9 kg
Resources
The following resources are available for the Xerox Phaser 7500N Colour Laser Printer
