Xerox Phaser 7500DN Colour Laser Printer
Quicklinx: 6957WS00 Mfr#: 7500V_DN?GB
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: LED
£2,185.58 ex VAT
£2,622.69 inc VAT
Save big when you bring your workgroup's diverse and high-volume color printing in house. The Phaser 7500 sports plenty of features that make it a perfect fit for the office on-demand print environment.
Produce brilliant, accurate color right "out of the box". The Phaser 7500 printer delivers the tools to make you look like a color expert.
Running complex jobs doesn't have to be complicated. The Phaser 7500 offers superior printer management capabilities and innovative features that make it especially easy to use.
  • Fast 35 ppm color printing
    That means 100 copies of your 20-page color report will print during your lunch hour. The high-speed 1 GHz processor ensures that both long print runs and complex jobs with graphics, photos or charts process rapidly.
  • Increase accountability and reduce costs
    Use accounting features to track and analyze both color and black-only printing, and to accurately charge back billing for individuals or departments.
  • Bring more types of jobs in house
    Produce professional-looking brochures, newsletters and reports with features such as automatic two-sided printing, booklet printing and collation. Print on an array of media, including labels and card stock.
  • So precise
    So precise, the color you're matching does exactly what you expect - it matches. The secret? It uses the tools of the pros: True Adobe PostScript 3 ensures that visually rich documents print reliably and fast, while Pantone-approved color tables make sure that specified colors print accurately and consistently.
  • A powerful color technology
    A powerful color technology works behind the scenes to automatically give you the best color for each element on the page. Use it to select automatic presets to match a specific target, like a press or your computer screen. Or get creative and use it to fine-tune color and get special effects without changing your file.
  • Expert-level tools are built in
    Expert-level tools are built in, including the Black Trapping feature, which keeps text sharp and readable whether printed in black on colored backgrounds or in color on black backgrounds.
  • The easy-open access is right up front
    The easy-open access is right up front; no need to rotate or move the printer to perform routine maintenance like changing toner and adding paper.
Xerox Phaser 7500DN - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
66 kg
Max Media Size
320 x 1200 mm
Print Speed
Up to 35 ppm - B/W , Up to 35 ppm - colour
Max Resolution (B&W)
1200 dpi
Max Resolution (Colour)
1200 dpi
Automatic Duplexing
USB, Gigabit LAN
Power QUICC III 1 GHz
RAM Installed (Max)
512 MB (2 GB) - DDR2 SDRAM - SO-DIMM 200-pin
Language Simulation
PCL 5C, PostScript 3, PDF 1.4
Media Type
Envelopes, transparencies, labels, plain paper, banners, cards, cover paper, glossy paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
AC 230V
Microsoft Windows 2000, SunSoft Solaris 8, SunSoft Solaris 9, HP-UX 11i v2, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, SunSoft Solaris 10, Red Hat Fedora Core 1, Red Hat Fedora Core 2, HP-UX 11, Red Hat Fedora Core 4, SuSE Linux 10.0, IBM AIX 5L 5.3, Red Hat Fedora Core 3, Red Hat Fedora Core 5, Red Hat Linux 4, Microsoft Windows Vista / XP, Microsoft Windows Server 2008
Microsoft Certification
Works with Windows Vista
Environmental Standards
EPEAT Silver
1-year warranty
64 cm x 66.5 cm x 39.9 cm
Printer Type
Printer
Print Speed
Wired
USB, Gigabit LAN
1200 dpi
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7 sec
First Print Out Time Colour
7 sec
Language Simulation
Fonts Included
81 x PCL 5c , 139 x PostScript
Colour Management Features
PANTONE Digital Color
Media Handling
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Technology / Form Factor
Slots Qty
2
Empty Slots
1
Media Handling
Media Type
Max Media Size
320 x 1200 mm
Media Weight
67 g/m² - 280 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - 320 x 1200 mm weight: 67 g/m² - 280 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 67 g/m² - 256 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
400 sheets
Duty Cycle
150000 pages
Print server
Network / Transport Protocol
TCP/IP, UDP/IP, LPR/LPD, FTP, DHCP
Remote Management Protocol
SNMP 3, IPP, HTTP, HTTPS, FTP
Security Protocols & Features
Secure Print, IPsec, 802.1x
IEEE 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 19800 pages , 1 x toner cartridge (cyan) - up to 9600 pages , 1 x toner cartridge (magenta) - up to 9600 pages , 1 x toner cartridge (yellow) - up to 9600 pages
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
FCC Class A certified, FCC Part 15, RoHS, UL 60950-1, CSA C22.2 No. 60950-1-03, Section 508
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
670 Watt
Power Consumption Stand by / Sleep
95 Watt
Software Included
Drivers & Utilities
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 80%
Sound Emission (Operating)
51 dBA
Sound Emission (Quiet Mode)
26 dBA
64 cm
66.5 cm
39.9 cm
66 kg
Width (Shipping)
76.7 cm
Depth (Shipping)
65 cm
Height (Shipping)
78.2 cm
Weight (Shipping)
83.9 kg
Ink (10)
6957 Xerox PHASER 7500 SC CYAN TONER In Stock £282.31
6957 Xerox PHASER 7500 SC MAGENTA TONER In Stock £282.31
6957 Xerox Phaser 7500 SC Yellow Toner In Stock £282.31
6957 Xerox Phaser 7500 HC Black Toner In Stock £277.97
6957 Xerox Phaser 7500 HC Cyan Toner In Stock £407.52
6957 Xerox PHASER 7500 HC MAGENTA TONER In Stock £412.99
6957 Xerox Phaser 7500 HC Yellow Toner In Stock £406.21
6957 Xerox Imaging Unit for Phaser 7500 In Stock £89.00
6957 Xerox Waste Toner Cartridge for 7500 In Stock £36.39
6957 Xerox Phaser 7500 Fuser Unit In Stock £131.51
Other bundles (4)
6957 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.83
6957 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.13
6957 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.19
6957 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.16
Resources
The following resources are available for the Xerox Phaser 7500DN Colour Laser Printer
Type: Printer
Output Type: Colour
Technology: LED
Max Print Speed: 35ppm
Max Paper Size: 320 x 1200 mm
Brand: Xerox
Price Range Ex VAT: 1500+
