The Phaser 6700 color printer accelerates work group productivity, giving you more time to focus on what matters most: the success of your business. With the combination of exceptional image quality and impressive fast print speed, the Xerox Phaser 6700 takes your business or large work group to a new level of high-volume productivity. You get unbeatable color accuracy on every business-critical document you print, with the added benefits of superior ease-of-use and renowned reliability that come from Xerox.
Eligible for free lifetime service coverage with Xerox eConcierge.
Xerox Phaser 6700 Colour Laser Printer
The Phaser 6700 colour laser printer accelerates work group productivity, giving you more time to focus on what matters most: the success of your business. With the winning combination of exceptional image quality and impressive fast print speed, the Xerox Phaser 6700 takes your business or large work group to a new level of high-volume productivity. You get unbeatable colour accuracy on every business-critical document you print, with the added benefits of superior ease-of-use and renowned reliability that only come from Xerox. -
Quick Facts
•Colour: up to 45 ppm Black: up to 45 ppm • Maximum paper size: 216 x 356 mm • Two-sided output standard on 6700/DN, DT and DX configurations • Finishing option adds 1000-sheet stacking and 50-sheet stapling • True 2400 x 1200 dpi print resolution • Advanced ease-of-use and security features • Optional Productivity Kit with 160 GB hard drive (standard on DX model) • Mac, Windows (including Vista), Unix, Linux, and Citrix compatible • Maximum duty cycle of up to 120,000 pages per month • Minimum dimensions (w x d x h): 560 x 516 x 429 mm • Power requirements: 240 V, 50/60 Hz • What comes in the box • Colour toner cartridges (capacity: 5,000 pages each1) • Black toner cartridge (capacity: 7,100 pages1) • Drum cartridges2 (capacity: 50,000 pages per colour, 50,000 pages black) • Power cord • Software and documentation -
Productivity Features
•Superior print quality thanks to true 2400 x 1200 dpi print resolution and true Adobe PostScript 3 • Incredible performance, with a colour and black-and-white print speed of up to 45 ppm • The 120,000-page monthly duty cycle supports the heaviest office print volumes • 1.25 GHz processor and standard 1 GB system memory handle a steady stream of complex jobs with ease • The Print Around feature eliminates extended printing delays by holding a job in need of resources (such as a different paper size) and printing the next job in the queue • Finisher option allows you to add 1000-sheet stacking and 50-sheet stapling -
Ease-of-use Features
•The large, 109 mm colour touch screen interface makes it ultra easy to find the functions you need • Embedded help videos provide quick troubleshooting assistance right on the front panel • Color By Words lets you select desired colour modifications from a simple drop-down list • Smart Trays alleviate guesswork by showing all available media types and sizes at print time -
Resource-conserving Features
•Standard duplexing on Phaser 6700/DN, DT and DX configurations help you reduce paper consumption • Innovative EA Toner requires a lower fusing temperature than traditional toner while offering glossy, beautiful office graphics • The Phaser 6700/DN, DT and DX configurations support the highest ENERGY STAR standards for power-saving. -
Security Features
•State-of-the-art security includes free 256-bit encryption using the FIPS 140-2 standard, plus built-in support for IPv6, IPsec, secure HTTPS, and other industry-standard network security features • Optional Productivity Kit with Hard Drive includes the Secure Print feature which holds private print jobs in the queue until they're released at the device by the job owner (standard on DX model) • Available Image Overwrite feature completely removes unneeded data from the Phaser 6700 colour printer's internal storage 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode. 2 Approximate pages. Declared Yield on Drums based on an average job size of 4 pages A4/letter size. Declared Yield on Fusers based on A4/letter size 20 lb (75 gsm) pages. Drum and Fuser Yields will vary based on job run length, media type, size, weight, orientation, and usage patterns.
- Xerox Phaser 6700Dn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 42.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN
- Processor
- 1.25 GHz
- RAM Installed (Max)
- 1 GB (2 GB)
- Language Simulation
- PCL 5E, PCL 5C, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight glossy paper, recycled paper
- Total Media Capacity
- 700 sheets
- Media Handling
- 150-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 120000 impressions
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- HP-UX 11.0, Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows XP, HP-UX 11i, Microsoft Windows Server 2003, Microsoft Windows 7, Red Hat Enterprise Linux 4, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Fedora Core 11, Red Hat Fedora Core 12, Oracle Solaris 10 9/10, IBM AIX 5, Red Hat Fedora Core 13, SuSE Linux 11.x
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 56 cm x 51.6 cm x 42.9 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD, touch screen
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 2400 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 8 sec
- Fonts Included
- 173 x PostScript , 94 x PCL
- Colour Management Features
- PANTONE Digital Color
- Media Handling
- Processor
- 1.25 GHz
RAM
- 1 GB / 2 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), 133.4 x 184.2 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 700 sheets
- Media Feeders
- 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 2900 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- Networking
- Print server
- Data Link Protocol
- TCP/IP, SMTP
- Remote Management Protocol
- SNMP 3, HTTPS
- SSL, Apple Bonjour, IPsec, 802.1x
- Connections
- 1 x USB - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 7100 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19798 , 1 x drum (black) - up to 50000 pages , 1 x drum (cyan) - up to 50000 pages , 1 x drum (magenta) - up to 50000 pages , 1 x drum (yellow) - up to 50000 pages
- GOST, FCC Part 15, UL 60950-1, CAN/CSA C22.2 No. 60950-1-07
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 672 Watt
- Power Consumption Stand by / Sleep
- 118 Watt
- Software Included
- Drivers & Utilities
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
- Sound Emission (Idle)
- 26 dBA
- Sound Emission (Operating)
- 59 dBA
- 56 cm
- 51.6 cm
- 42.9 cm
- 42.2 kg
