The Phaser 6500 is a fast reliable color printing perfect for your office. The right solution for today's pace of business, this printer gives your important documents a powerful, colorful boost. From arrival to disposal, the Phaser 6500 helps you meet today's environmental challenges.
A smaller footprint means you can locate the Phaser 6500 where it's most convenient. Easy installation and pre-loaded toner cartridges make this printer virtually plug-and-play. Superior performance gets your jobs out quickly, with print color and black-and-white print speeds up to 24 ppm.
Count on consistently precise print jobs with bright, true colors and superior graphics. Xerox-exclusive EA toner uses particles engineered for uniform size and shape, producing superior image detail and line definition, and text that's sharp and clear.
The Phaser 6500 is a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity, and day-in, day-out dependability.
Phaser 6500
The Xerox Phaser 6500 colour printer. Today's busy workteams need a value-packed colour device that handles all of your printing needs with that rare combination of outstanding print quality, unparalleled simplicity, and day-in, day-out dependability. Get total peace of mind with our one-year, on-site warranty. -
Quick Facts
•Colour: up to 23 ppm • Black: up to 23 ppm • Maximum paper size: 216 x 356 mm • Print resolution: up to 600 x 600 x 4 dpi • Standard paper capacity: Tray 1: 250 sheets • Maximum paper capacity: 500 sheets • 400 MHz processor • 256 MB memory standard, 768 MB maximum • Windows (including Windows 7) and Mac compatible • Minimum dimensions (w x d x h): 403.5 x 425.5 x 415.6 mm • Power requirements: 240 V, 50/60 Hz • What comes in the box • Print cartridge (capacity: 1,000 pages each1) • Power cord • Software and documentation -
Print Quality Features
•A print resolution of up to 600 x 600 x 4 dpi delivers an amazing 16 shades of colour per pixel. That means a wider colour range for more impressive business graphics • Unique Xerox EA toner technology gives you crisp text and printed images with superior detail and clarity. It's the same high-quality toner used in our professional graphic-arts colour devices • True Adobe PostScript 3 means you can count on consistently precise print jobs with bright, true colours and superior graphics • PANTONE Colour approved solid-colour simulations and Xerox colour correction technology provide easy tools for precisely matching the colours of important business assets, such as company logos -
Reliability and Ease-of-use Features
•The intuitive LCD user interface features a convenient gauge that shows current toner levels at a glance • The CentreWare IS internal web server makes it easy to handle device administration right from your computer's browser • Outstanding reliability is backed by Xerox with a one-year on-site warranty • Easy installation and pre-loaded toner cartridges make this printer virtually plug-and-play • Simple supplies replacement via convenient side door access • The Run Black feature lets you keep printing in black-and-white even if the printer runs out of colour toner -
Productivity Features
•The value-packed Phaser 6500 colour printer means serious business for your workteam, providing real-world print productivity and a host of built-in features • Superior performance gets your jobs out quickly, with print colour and black-and-white print speeds up to 23 ppm • A powerful 400 MHz processor and 256 MB standard memory handle your workteam's demanding workload - even multipage print jobs with graphics, photos and charts -
Environmentally Responsible Features
•Print more, use less. Whether you choose manual two-sided printing, or upgrade to convenient automatic duplexing, you'll conserve paper for reduced costs and increased sustainability • With minimal packaging, our toner-only cartridges allow for 80% less waste than comparable colour devices using integrated print cartridges, and also let you easily store backup toner in a desk drawer • A small footprint allows for easy integration within your work space, whether on your desk or in a shared location • Extra-quiet operation to minimize impact on busy offices 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19798. Yield will vary based on image, area coverage and print mode.
- Xerox Phaser 6500N - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 18.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 23 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Interface
- USB, Gigabit LAN, USB host
- Processor
- 400 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PostScript 3, PCL 6
- Media Type
- Envelopes, labels, plain paper, business cards, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 40000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- Printer Features
- Optional duplex, 4-bit depth colour technology
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver
- 1-year warranty
- 40.4 cm x 42.6 cm x 41.6 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 600 dpi
- 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
- Colour Management Features
- PANTONE Digital Color
- Printer Features
- Media Handling
- Processor
- 400 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 216 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 40000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP 3, HTTPS
- SSL, IPsec, 802.1x
- IEEE 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x direct print port - USB 2.0 - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 375 Watt
- Power Consumption Stand by / Sleep
- 55 Watt
- Software Included
- Xerox CentreWare IS Embedded Web Server, Xerox CentreWare Web, Xerox PrintingScout
- OS Required
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
- Sound Emission (Idle)
- 25 dBA
- Sound Emission (Operating)
- 53 dBA
- 40.4 cm
- 42.6 cm
- 41.6 cm
- 18.2 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
