Xerox Phaser 4622V_DN Mono Laser Printer
Quicklinx: CCHLWS00 Mfr#: 4622V_DN?GB
Print more in less time. The Phaser 4622 meets your productivity challenge at a value price, giving your work group heavy-duty reliable performance - page after page, year after year.
  • Raise the bar on performance
    With print speeds of up to 62 ppm and a monthly duty cycle of 275,000 prints, it's never been easier to keep a productive pace.
  • Fast output
    As few as 7.8 seconds from the time you press start to your first page view.
  • Swift throughput
    The Phaser 4622's dual core floating point processor provides swift throughput.
  • Exceptional sharpness and clarity
    With image quality of up to 1200 x 1200, you'll clearly see the difference with every document.
  • Keep the peace
    The Phaser 4622 is engineered for exceptionally quiet operation to minimize the impact on busy offices.
  • Print on the go
    With native support for Apple Airprint, the Phaser 4622 gives you access to the most widely used mobile print tool.
  • Easy does it
    The simplified front console and automated setup feature enable printing in minutes.
  • Print out of the box
    Print on just about everything from transparencies, to card stock, to envelopes and labels - and more.
  • Paper cuts
    Highly efficient, hassle-free two-sided printing can easily cut your paper consumption in half while saving you time and money.
  • Reduce paper costs
    Single sheet, N-up printing lets you group multiple pages on a single sheet, so you cut down on paper usage and cost.
  • Use consumables more efficiently
    Split consumables mean you replace only what you use - so you get the most out of every user-replaceable component.
Xerox Phaser 4622V_DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
34.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 43 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
600 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, EPSON
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, card stock, light-weight paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
275000 pages
Recommended Monthly Volume
6000 pages
Print server
Microsoft Windows XP SP1, HP-UX 11i v2, Microsoft Windows Server 2003, openSUSE 11.0, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Ubuntu, Red Hat Fedora 13, Red Hat Fedora 11, Red Hat Fedora 12, Red Hat Fedora 14, IBM AIX 5, Windows 8, Microsoft Windows Server 2012, Windows 8.1
1-year warranty
47.6 cm x 54.1 cm x 42 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.8 sec
Language Simulation
Fonts Included
136 x PostScript , 93 x PCL
Media Handling
600 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), 98.6 x 148.5 mm
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 100 sheets - 216 x 356 mm weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - 216 x 356 mm weight: 60 g/m² - 163 g/m²
Max Sheets in Multi-Part Form
3750
Output Trays Capacity
500 sheets
Duty Cycle
275000 pages
6000 pages
Print server
Remote Management Protocol
SNMP 3
Security Protocols & Features
Secure Print, SSL, IPsec, 802.1x, IP filtering
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 13000 pages ISO/IEC 19752 , 1 x drum - up to 80000 pages
EN55024, EN55022 Class A, EMC, FCC Part 15, ICES-003 Class A, RoHS, UL 60950-1, WEEE, FDA, EN 60825-1, CDRH, EN 60950-1 Second Edition, Directive 2002/96/EC, Directive 2011/65/EC, CSA C22.2 No. 60950-1-07 + A1, EMC 2004/108/EC, LVD 2006/95/EC
Power supply - internal
Frequency Required
50/60 Hz
900 Watt
Power Consumption Stand by
120 Watt
Power Consumption Sleep
2.8 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
20 - 85%
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
58 dBA
Sound Emission (Quiet Mode)
52 dBA
47.6 cm
54.1 cm
42 cm
34.6 kg
Width (Shipping)
62.7 cm
Depth (Shipping)
69.8 cm
Height (Shipping)
68.5 cm
Weight (Shipping)
40.2 kg
