Print more in less time. The Phaser 4622 meets your productivity challenge at a value price, giving your work group heavy-duty reliable performance - page after page, year after year.
Raise the bar on performance
With print speeds of up to 62 ppm and a monthly duty cycle of 275,000 prints, it's never been easier to keep a productive pace. -
Fast output
As few as 7.8 seconds from the time you press start to your first page view. -
Swift throughput
The Phaser 4622's dual core floating point processor provides swift throughput. -
Exceptional sharpness and clarity
With image quality of up to 1200 x 1200, you'll clearly see the difference with every document. -
Keep the peace
The Phaser 4622 is engineered for exceptionally quiet operation to minimize the impact on busy offices. -
Print on the go
With native support for Apple Airprint, the Phaser 4622 gives you access to the most widely used mobile print tool. -
Easy does it
The simplified front console and automated setup feature enable printing in minutes. -
Print out of the box
Print on just about everything from transparencies, to card stock, to envelopes and labels - and more. -
Paper cuts
Highly efficient, hassle-free two-sided printing can easily cut your paper consumption in half while saving you time and money. -
Reduce paper costs
Single sheet, N-up printing lets you group multiple pages on a single sheet, so you cut down on paper usage and cost. -
Use consumables more efficiently
Split consumables mean you replace only what you use - so you get the most out of every user-replaceable component.
- Xerox Phaser 4622V_DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 34.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 43 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 600 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF, EPSON
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, card stock, light-weight paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 275000 pages
- Recommended Monthly Volume
- 6000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP SP1, HP-UX 11i v2, Microsoft Windows Server 2003, openSUSE 11.0, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Ubuntu, Red Hat Fedora 13, Red Hat Fedora 11, Red Hat Fedora 12, Red Hat Fedora 14, IBM AIX 5, Windows 8, Microsoft Windows Server 2012, Windows 8.1
- 1-year warranty
- 47.6 cm x 54.1 cm x 42 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.8 sec
- Fonts Included
- 136 x PostScript , 93 x PCL
- Media Handling
- Processor
- 600 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 98.6 x 148.5 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 216 x 356 mm weight: 60 g/m² - 220 g/m² , 1 x automatic - 550 sheets - 216 x 356 mm weight: 60 g/m² - 163 g/m²
- Max Sheets in Multi-Part Form
- 3750
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 275000 pages
- 6000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3
- Secure Print, SSL, IPsec, 802.1x, IP filtering
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 13000 pages ISO/IEC 19752 , 1 x drum - up to 80000 pages
- EN55024, EN55022 Class A, EMC, FCC Part 15, ICES-003 Class A, RoHS, UL 60950-1, WEEE, FDA, EN 60825-1, CDRH, EN 60950-1 Second Edition, Directive 2002/96/EC, Directive 2011/65/EC, CSA C22.2 No. 60950-1-07 + A1, EMC 2004/108/EC, LVD 2006/95/EC
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 900 Watt
- Power Consumption Stand by
- 120 Watt
- Power Consumption Sleep
- 2.8 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 20 - 85%
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 58 dBA
- Sound Emission (Quiet Mode)
- 52 dBA
- 47.6 cm
- 54.1 cm
- 42 cm
- 34.6 kg
- Width (Shipping)
- 62.7 cm
- Depth (Shipping)
- 69.8 cm
- Height (Shipping)
- 68.5 cm
- Weight (Shipping)
- 40.2 kg
