Produce professional-looking documents quickly with the Xerox Phaser 3610 monochrome laser printer. You'll get best-in-class speed, expanded capabilities and crisp print quality for your busy office. With best-in-class speed, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Productivity and Print Quality
With best-in-class speed*, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Built for speed
Print up to 45 pages per minute (ppm) the fastest monochrome print speed in its class*. Your first page prints in as few as 6.5 seconds.
Expand your capabilities.
Adding up to three optional trays let you expand your work to fit different paper sizes and stocks, or extend media capacity during peak workloads.
Crisp details.
Bring definition and clarity to your documents with true print resolution of up to 1200 x 1200 dpi. Your printed communications never looked better.
When compared to similar products as of September 2013.
Powerful Capabilities Built for Savings
Advanced tools improve security and save paper, power and time.
Reduce paper usage.
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet a useful option when sharing presentations.
Increase efficiency.
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done.
Keep information safe.
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents.
Use less power.
Unique Xerox EA Toner fuses at a much lower temperature, reducing power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner.
Work From Anywhere.
When youre on the go, you can still print to the Phaser 3610, and manage it remotely from a web browser.
Print when and where you want.
With Apple AirPrint, you can print email, and important office documents, directly from your mobile iOS device when connected to your office Wi-Fi network.
And when working offsite, you can rely on Xerox PrintBack to print documents back at the office so they are waiting for you when you return.
Freedom, unplugged.
With optional Wi-Fi capabilities, the Phaser 3610 is ready to go to work wherever its needed.
Manage from a web browser.
Handle device administration remotely from any networked computer with Xerox® CentreWare® IS.
Productivity and print quality
With best-in-class speed, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting. -
Built for speed
Print many pages per minute - the fastest monochrome print speed in its class. Your first page prints very fast. -
Powerful capabilities built for savings
Advanced tools improve security and save paper, power and time. -
Reduce paper usage
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet - a useful option when sharing presentations. -
Increase efficiency
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done. -
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents. -
Work from anywhere
When you're on the go, you can still print to the Phaser 3610, and manage it remotely from a web browser. -
Freedom, unplugged
With optional Wi-Fi capabilities, the Phaser 3610 is ready to go to work wherever it's needed.
- Xerox Phaser 3610V/DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 13 kg
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 28 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- Gigabit LAN, USB host
- Processor
- 400 MHz
- RAM Installed (Max)
- 512 MB (1 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF
- Media Type
- Envelopes, labels, plain paper, heavy-weight paper, thick paper, card stock, light-weight paper
- Total Media Capacity
- 700 sheets
- Media Handling
- 150-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 110000 pages
- Recommended Monthly Volume
- 14000 pages
- Networking
- Print server
- Printer Features
- Fit-to-page
- System Requirements
- Microsoft Windows XP SP1, HP-UX 11i v2, Microsoft Windows Server 2003, openSUSE 11.0, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Ubuntu, IBM AIX 5, Red Hat Fedora Core 11 - 14
- 39.3 cm x 42.6 cm x 31.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Fonts Included
- 96 x PCL , 87 x PostScript
- Printer Features
- Fit-to-page
- Media Handling
- Processor
- 400 MHz
RAM
- 512 MB / 1 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), 76 x 127 mm, 216 x 356 mm
- Media Weight
- 60 g/m² - 216 g/m²
- 700 sheets
- Media Feeders
- 1 x automatic - 150 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m² , 1 x automatic - 550 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m² , 1 x automatic (optional) - 550 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 2350 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 110000 pages
- 14000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS
- LDAP, Secure Print, SSL, IPsec, 802.1x, IP filtering
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 5900 pages
- EN55022 Class B, ICES-003 Class A, RoHS, Laser Class 1, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, WEEE, FDA, EN 60825-1, FCC Part 15 B Class A, CDRH, Directive 2004/108/EC, Directive 2006/95/EC, Directive 2002/96/EC, Directive 2011/65/EU
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 686 Watt
- Power Consumption Stand by
- 52 Watt
- Power Consumption Sleep
- 2 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 15 °C
- 28 °C
- 20 - 70%
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 56 dBA
- 39.3 cm
- 42.6 cm
- 31.5 cm
- 13 kg
- Width (Shipping)
- 53.4 cm
- Depth (Shipping)
- 54 cm
- Height (Shipping)
- 47 cm
- Weight (Shipping)
- 15.9 kg
Ink (4)
Xerox 3610 High Capacity Black Toner Cartridge | In Stock | £299.83 |
Xerox 3610 Extra High Capacity Black Toner Cartridge | In Stock | £368.10 |
Xerox SMart Kit for Phaser 3610; WorkCentre 3615, 3655 | In Stock | £71.79 |
Xerox Standard Capacity Black Toner Cartridge | In Stock | £164.30 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
