Xerox Phaser 3610DN A4 Mono USB Laser Printer
Quicklinx: 95YRWS00 Mfr#: 3610V_DN
Produce professional-looking documents quickly with the Xerox Phaser 3610 monochrome laser printer. You'll get best-in-class speed, expanded capabilities and crisp print quality for your busy office. With best-in-class speed, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Productivity and Print Quality
With best-in-class speed*, print resolution and media capacity, your busy office can deliver professional-looking prints, without waiting.
Built for speed
Print up to 45 pages per minute (ppm) the fastest monochrome print speed in its class*. Your first page prints in as few as 6.5 seconds.
Expand your capabilities.
Adding up to three optional trays let you expand your work to fit different paper sizes and stocks, or extend media capacity during peak workloads.
Crisp details.
Bring definition and clarity to your documents with true print resolution of up to 1200 x 1200 dpi. Your printed communications never looked better.
When compared to similar products as of September 2013.
Powerful Capabilities Built for Savings
Advanced tools improve security and save paper, power and time.
Reduce paper usage.
You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet a useful option when sharing presentations.
Increase efficiency.
Extra-high capacity toner cartridges allow you spend less time loading supplies and more time getting work done.
Keep information safe.
Secure Print keeps your sensitive documents out of the wrong hands by requiring users to enter a personal identification number at the device to print documents.
Use less power.
Unique Xerox EA Toner fuses at a much lower temperature, reducing power consumption by up to 20% and CO2 emissions by up to 35%, compared to conventional toner.
Work From Anywhere.
When youre on the go, you can still print to the Phaser 3610, and manage it remotely from a web browser.
Print when and where you want.
With Apple AirPrint, you can print email, and important office documents, directly from your mobile iOS device when connected to your office Wi-Fi network.
And when working offsite, you can rely on Xerox PrintBack to print documents back at the office so they are waiting for you when you return.
Freedom, unplugged.
With optional Wi-Fi capabilities, the Phaser 3610 is ready to go to work wherever its needed.
Manage from a web browser.
Handle device administration remotely from any networked computer with Xerox® CentreWare® IS.
  • Productivity and print quality
  • Built for speed
    Print many pages per minute - the fastest monochrome print speed in its class. Your first page prints very fast.
  • Powerful capabilities built for savings
  • Reduce paper usage
    You'll dramatically lower your paper usage and related costs thanks to automatic two-sided printing. Plus, N-up printing enables you to print multiple pages on one sheet - a useful option when sharing presentations.
  • Increase efficiency
  • Keep information safe
  • Work from anywhere
    When you're on the go, you can still print to the Phaser 3610, and manage it remotely from a web browser.
  • Freedom, unplugged
    With optional Wi-Fi capabilities, the Phaser 3610 is ready to go to work wherever it's needed.
Xerox Phaser 3610V/DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
13 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 28 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
Gigabit LAN, USB host
400 MHz
RAM Installed (Max)
512 MB (1 GB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF
Media Type
Envelopes, labels, plain paper, heavy-weight paper, thick paper, card stock, light-weight paper
Total Media Capacity
700 sheets
Media Handling
150-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
110000 pages
Recommended Monthly Volume
14000 pages
Print server
Printer Features
Fit-to-page
Microsoft Windows XP SP1, HP-UX 11i v2, Microsoft Windows Server 2003, openSUSE 11.0, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Ubuntu, IBM AIX 5, Red Hat Fedora Core 11 - 14
39.3 cm x 42.6 cm x 31.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
Language Simulation
Fonts Included
96 x PCL , 87 x PostScript
Printer Features
Fit-to-page
Media Handling
400 MHz
RAM
RAM Installed (Max)
512 MB / 1 GB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), 76 x 127 mm, 216 x 356 mm
Media Weight
60 g/m² - 216 g/m²
700 sheets
Media Feeders
1 x automatic - 150 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m² , 1 x automatic - 550 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m² , 1 x automatic (optional) - 550 sheets - 216 x 356 mm weight: 60 g/m² - 216 g/m²
Max Media Capacity
2350 sheets
Output Trays Capacity
250 sheets
Duty Cycle
110000 pages
14000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
LDAP, Secure Print, SSL, IPsec, 802.1x, IP filtering
1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 5900 pages
EN55022 Class B, ICES-003 Class A, RoHS, Laser Class 1, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, WEEE, FDA, EN 60825-1, FCC Part 15 B Class A, CDRH, Directive 2004/108/EC, Directive 2006/95/EC, Directive 2002/96/EC, Directive 2011/65/EU
Power supply - internal
Frequency Required
50/60 Hz
686 Watt
Power Consumption Stand by
52 Watt
Power Consumption Sleep
2 Watt
Environmental Standards
Blue Angel
ENERGY STAR
15 °C
28 °C
20 - 70%
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
56 dBA
39.3 cm
42.6 cm
31.5 cm
13 kg
Width (Shipping)
53.4 cm
Depth (Shipping)
54 cm
Height (Shipping)
47 cm
Weight (Shipping)
15.9 kg
Ink (4)
95YR Xerox 3610 High Capacity Black Toner Cartridge In Stock £300.48
95YR Xerox 3610 Extra High Capacity Black Toner Cartridge In Stock £368.89
95YR Xerox SMart Kit for Phaser 3610; WorkCentre 3615, 3655 In Stock £71.94
95YR Xerox Standard Capacity Black Toner Cartridge In Stock £164.66
Other bundles (1)
95YR C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
