Achieve your objectives. The Phaser 3260 printer and is compact, yet extremely powerful. It is designed to support either a single user or a small team. The Phaser 3260 features fast, automatic two-sided printing with crisp, clear text and graphics.
Budget friendly
Keep your costs down with fast, reliable printing for a single user or small team. -
Count on it
Keep intervention to a minimum with long lasting, easy to replace cartridges and reliable operation that handles every job with ease. -
Print efficiently
Split supplies mean you replace only what you use - so you get the most out of every print cartridge. -
Quick print
A print speed of up to 28 ppm and a rapid first page-out time as fast as 8.5 seconds, enable you to spend less time at the device and more time focusing on your business. -
Save more than money
Standard, automatic two-sided printing saves valuable time and paper, while Power Save and Toner Save modes, and the Earth Smart print driver, let you choose to spend less on electricity and consumables. -
Visual impact
Printing at 4800 x 600 dpi enhanced image quality, together with PCL and PostScript emulations, ensures consistently clear text and sharp graphics. -
Wi-Fi Direct
Now mobile phones, tablets and laptop computers can make a secure connection directly to the printer or multifunction printer even if you don't have an existing wireless network. -
It's not complicated
The Xerox Easy Wireless Setup helps you connect quickly and easily to your Wi-Fi network. -
Easy to reach
These devices, featuring quiet operation, built-in wireless networking and compact designs, fit exactly where you need them to be most productive.
- Xerox Phaser 3260V_DNI - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 7.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 29 ppm - B/W , Up to 28 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 4800 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 600 MHz
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Networking
- Print server
- Printer Features
- Fit-to-page
- Power
- AC 230V
- System Requirements
- HP-UX 11.0, Microsoft Windows 2000, IBM AIX 5.1, HP-UX 11i v2, HP-UX 11i v1, openSUSE 11.0, SunSoft Solaris x86 10, SunSoft Solaris x64 9, SUSE Linux Enterprise Desktop 11, SUSE Linux Enterprise Desktop 10, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Vista (32/64 bits), Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Red Hat Fedora 11, IBM AIX 7.1, SunSoft Solaris x86 11, Debian Linux 5.0, Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Apple MacOS X 10.5 - 10.9, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Red Hat Fedora 19
- 2-year warranty
- 36.8 cm x 33.5 cm x 21.4 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 4800 x 600 dpi
- PostScript Support
- Included
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 136 x PostScript , 111 x PCL
- Printer Features
- Fit-to-page
- Media Handling
- Processor
- 600 MHz
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS
- SSL, WPA2, IPsec, 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1500 pages ISO/IEC 19752 , 1 x drum - up to 10000 pages
- EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, WEEE, FDA, EN 60825-1, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC, CSA C22.2 No. 60950-1-07 Second Edition, Directive 2012/19/EU, Directive 2011/65/EU
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 417 Watt
- Power Consumption Stand by
- 46 Watt
- Power Consumption Sleep
- 2 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 2 years - pick-up and return
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 53 dBA
- 36.8 cm
- 33.5 cm
- 21.4 cm
- 7.6 kg
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.13 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.84 |
