There is super power packed in this small scanner. Capable of scanning a variety of documents, including long, small, thick and thin sheets, the DocuMate 5460 will greatly boost the efficiency of your office. Conveniently small enough to fit on the reception desk of a medical office or bank, the scanner is designed to quickly scan customer or patient ID cards and other documents, enabling real-time information sharing to provide fast, accurate customer service.
The scanners have a convenient interface that allows the user to simply insert their document and press one button on the front panel to initiate scanning and automatically email, print, convert or share their document.
- Xerox DocuMate 5460 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- 216 x 2540 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
- 216 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 4000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- 31.8 cm x 28 cm x 24.1 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 2540 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 60 ppm
- Duty Cycle
- Scanner Speed Details
- 60 ppm - black & white - A4 - 200 dpi , 60 ppm - colour - A4 - 200 dpi , 60 ppm - black & white - Letter - 200 dpi , 60 ppm - colour - Letter - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 120 ipm - duplex - colour - 200 dpi , 120 ipm - duplex - black & white - Letter - 200 dpi , 120 ipm - duplex - colour - Letter - 200 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Dog-Ear Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 2540 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 216 x 2540 mm
- Automatic
- 75 sheets
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB
- 31.8 cm
- 28 cm
- 24.1 cm
- 4 kg
