Your basket is empty
Xerox DocuMate 4830 Document Scanner
Quicklinx: 9M4MWS00 Mfr#: 100N02872
The Xerox DocuMate 4830 is an effective way to index stacks of large-sized documents and import them to a content management solution in a single step. The DocuMate 4830 is an affordable, entry-level A3 scanner that offers outstanding performance and exceptional reliability for corporate workgroups/departments and small or medium-sized businesses.
The DocuMate 4830 has a friendly interface that allows the user to simply insert their document and press one of the buttons on the front panel of the scanner to initiate scanning and automatically email, print, convert or share the file. The buttons are preset at the optimal resolution, color depth, file format and paper size for common scanning tasks, but of course can be easily changed at any time. Ultrasonic Double Feed Detectionis built into the DocuMate 4830 so you'll never miss a page due to a misfeed or a stapled document going through the scanner.
Ideal for document management, the DocuMate 4830 includes software tools to edit, crop and retouch scanned images and organize the files into folders. With the touch of a button, users are able to scan and automatically upload their documents to popular cloud destinations such as Google Docs, Evernote, Dropbox.net and others.
Xerox DocuMate 4830 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
297 mm x 2997 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
3000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
58.1 cm x 49.9 cm x 19.4 cm
12 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - black & white - 200 dpi , 60 ipm - duplex - black & white - 200 dpi , 30 ppm - colour - 200 dpi , 60 ipm - duplex - colour - 200 dpi
Scanner Features
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 2997 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 2997 mm , Flatbed - up to A3 (297 x 420 mm)
Automatic
75 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Software Included
Nuance OmniPage Professional, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter Professional 7
System Requirements Details
Windows XP/Vista/7 - Pentium 4 RAM 2 GB - HD 350 MB
58.1 cm
49.9 cm
19.4 cm
12 kg
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
