Versatility, high-speed and superior reliability make the Xerox DocuMate 4799 a powerful scanner for demanding environments. With up to a 40,000 page per day duty cycle, this innovative workhorse scans up to 100 pages per minute and employs three advanced sensor systems: ultrasonic double feed detection, stapled document detection and intelligent feed control to ensure that your scan job will not get interrupted.
Documents of various sizes can be stacked together in the automatic feed tray without worry because the Xerox DocuMate 4799 employs not one, but three ultrasonic double feed detection sensors to cover the entire width of a document.
The scanner has another set of sensors designed to detect staples anywhere in a document. As soon as a staple is detected, the scanning process is halted - minimizing damage to the optical glass and your documents.
A third set of sensors constantly monitors the thickness of documents being fed into the scanner and automatically adjusts the roller pressure to ensure that all pages are accurately fed. This combination of sensors creates one of the most reliable feed mechanisms available today.
The Xerox DocuMate 4799 provides both high quality image enhancement and increased productivity with Kofax VRS Professional AIPE-EBC for auto-everything scanning, including auto rotation, blank page deletion and auto color detect. VRS Professional improves your workflow and reduces the total time needed to scan even the largest volumes of mixed batch documents.
The DocuMate 4799 also employs a device-independent color space that is compatible with the Xerox iGen digital press so that you can be assured that the color fidelity of your original translates to the output of your real time digital press.
When the occasional paper jam happens, the Xerox DocuMate 4799 is very easy to maintain. Its unique "clamshell" design allows full access to the entire paper path, so you can clear paper jams or clean the unit without calling a service technician. The rollers are easy to replace, improving the unit's cost effectiveness, and have a long service life.
Overcome your fear of difficult documents
Versatility, high-speed and superior reliability make the Xerox DocuMate 4799 a powerful scanner for demanding environments. With up to a 40,000 page per day duty cycle, this innovative workhorse scans up to 112 pages per minute and employs three advanced sensor systems: ultrasonic double feed detection, stapled document detection and intelligent feed control to ensure that your scan job will not get interrupted. Documents of various sizes can be stacked together in the automatic feed tray without worry because the Xerox DocuMate 4799 employs not one, but three ultrasonic double feed detection sensors to cover the entire width of a document. The scanner has another set of sensors designed to detect staples anywhere in a document. As soon as a staple is detected, the scanning process is halted - minimizing damage to the optical glass and your documents. A third set of sensor constantly monitors the thickness of document being fed into the scanner and automatically adjusts the roller pressure to ensure that all pages are accurately fed. This combination of sensors creates one of the most reliable feed mechanisms available today. -
Advanced Image Processing technology
The Xerox DocuMate 4799 provides both high quality image enhancement and increased productivity with Kofax VRS professional AIPE-EBC for auto-everything scanning. VRS Professional time needed to scan even the largest volumes of mixed batch documents. Taken together, the Xerox DocuMate 4799 and the Kofax VRS professional bundle translate into real and measurable savings fewer manual steps, reduced storage requirements and less operator intervention.
- Xerox DocuMate 4799 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Xe-gas cold cathode fluorescent lamp
- Max Supported Document Size
- 297 x 2540 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 100 ppm (mono) / 100 ppm (colour)
- Max Document Size
- 297 mm x 432 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 250 sheets
- Duty Cycle
- 40000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- 47.4 cm x 58.5 cm x 32.9 cm
- 25 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 297 x 2540 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Bulb / Light Source Type
- Max Document Scan Speed B/W
- 100 ppm
- Max Document Scan Speed Colour
- 100 ppm
- Duty Cycle
- Scanner Speed Details
- 200 ipm - duplex - black & white - 200 dpi , 100 ppm - black & white - 200 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology, Ionizer, built-in LCD screen
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 432 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 297 x 2540 mm
- Automatic
- 250 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Kofax VirtualReScan Professional, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
- 47.4 cm
- 58.5 cm
- 32.9 cm
- 25 kg
