Xerox DocuMate 4760 VRS Scanner
Quicklinx: 9M4WWS00 Mfr#: 100N02795
Xerox DocuMate 4760 w/ VRS Pro Duplex Document scanner A3 - 600 dpi - up to 5000 scans per day - USB 2.0
Xerox DocuMate 4760 w/ VRS Pro - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
A3 (297 x 420 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
297 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
150 sheets
Duty Cycle
5000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
42.7 cm x 27.7 cm x 21.8 cm
9 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
A3 (297 x 420 mm)
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
60 ppm - black & white - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 60 ppm - colour - 150 dpi , 120 ipm - duplex - colour - 150 dpi
Scanner Features
Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
297 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 297 x 965 mm
Automatic
150 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
39.5 Watt (11.4 Watt)
Software Included
Kofax VirtualReScan Professional, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
System Requirements Details
Windows XP SP2 - Pentium 4 RAM 1 GB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 2 GB - HD 350 MB
42.7 cm
27.7 cm
21.8 cm
9 kg
Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
