The DocuMate 4700 is an excellent flatbed scanner when directly connected to your PC. It also can become a flatbed option when connected to any Xerox DocuMate ADF scanner. Its USB hub changes the scanner to a combined configuration of distinct ADF and flatbed scanners that are addressable as one single scanner. So, if your needs suddenly change from the ADF-only scanner you have today, you can add a flatbed scanner and improve the investment you've already made in an ADF scanner. The ability to configure your DocuMate 4700 with an ADF scanner in series brings total flexibility to the entire DocuMate scanner product line.
The DocuMate 4700's powerful software, robust functionality and superior hardware specification delivers quality in every scan. Flatbed scanning offers the option to scan a wide variety of documents, such as books, magazines, plastic cards and fragile paper. Now there is no need to install multiple flatbed scanners across a network if the majority of users do not require this function on a frequent basis.
- Xerox DocuMate 4700 - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 297 mm x 432 mm
- Supported Document Type
- Plain paper
- Duty Cycle
- 1000 scans per day
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- 57.9 cm x 49.5 cm x 11.4 cm
- 6.99 kg
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- LED
- Duty Cycle
- Scanner Features
- Visioneer OneTouch Technology, Visioneer DriverPLUS Technology, Visioneer Acuity Technology
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 432 mm
- Plain paper
- Supported Document Size Details
- Flatbed - up to 297 x 432 mm
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Visioneer DriverPLUS, Nuance PDF Converter Professional
- OS Required
- System Requirements Details
- Pentium 4 RAM 2 GB - HD 500 MB
- 57.9 cm
- 49.5 cm
- 11.4 cm
- 6.99 kg
