Xerox Documate 3640 Pro A4 Flatbed Scanner
Quicklinx: C6XBWS00 Mfr#: 003R92156
The DocuMate 3640 is a departmental duplex flatbed scanner with the automatic document feeder (ADF) that scans in duplex mode. The A4/legal flatbed is the only departmental scanner that can be programmed to automatically scan customisable applications or devices. Ultrasonic double feed detection insures that no pages are missed due to a misfeed or stapled document in the ADF tray. Documents can be converted to text-searchable PDF in one easy step.
The Xerox DocuMate 3640 is the perfect solution for company wide scanning solutions and enables businesses to achieve high levels of productivity by distributing fast, costeffective departmental scanners throughout the organization.
  • Work smarter
    The DocuMate 3640's powerful software, robust functionality and hardware specifications deliver the speed and quality for departmental scanning. The DocuMate 3640 offers file format flexibility including text-searchable PDF. VRS also helps improve the accuracy of recognition software, thereby reducing the need for manual correction of intelligent character recognition and OCR results.
  • Vertical market solutions
    Regulatory compliance requirements have dramatically increased the need for companies to implement secure and reliable records for management and document capture solutions. Departmental scanners are ideal for document management in small to mid volume applications and may also be used to complement higher volumes products in distributed scanner settings.
  • Visioneer OneTouch
    Visioneer OneTouch is an easy to use utility that connects the DocuMate scanner with a powerful set of scanner settings to greatly improve the efficiency of your workflow - so that with one touch, the document is scanned automatically to email, Word, your printer, or simply a file folder.
  • Text searchable PDF
    Transform volumes of paper or photos into organized digital files that can be quickly found, used and shared. In searchable PDF format, the user can instantly search documents for keywords or phrases. This provides additional archival benefits beyond traditional storage, and the widely accepted PDF format lets everyone view and print documents - on any computer.
  • Nuance OmniPage Pro
    Provides a precise OCR and layout retention solution, quickly turning scanned documents into editable, formatted text. The text can then be used in virtually any word processing, desktop publishing or web publishing programe.
Xerox DocuMate 3640 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 965 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
5000 scans per day
Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
53.1 cm x 41.1 cm x 22.4 cm
10.3 kg
Interface Type
USB 2.0
216 x 965 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - duplex black & white (back) 200 dpi (back) , 80 ipm - duplex colour (back) 150 dpi (back) , 40 ppm black & white (back) 200 dpi (back) , 40 ppm colour (back) 150 dpi (back)
Scanner Features
Visioneer OneTouch with Kofax VRS Technology
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 965 mm , Flatbed - up to Legal (216 x 356 mm)
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
External power adapter
Software Included
QuickScan Pro (Demo), Kofax VirtualReScan Professional, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch
Additional Requirements
DVD-ROM, USB port
System Requirements Details
Windows 2000 SP4 - Pentium 4 RAM 512 MB - HD 500 MB , Windows XP SP2 - Pentium 4 RAM 512 MB - HD 500 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 500 MB
53.1 cm
41.1 cm
22.4 cm
10.3 kg
