The ColorQube 8880 ADN Solid Ink Color Printer means big savings on color printing thanks to its incredibly low total cost of ownership. You get a high-volume, no-fuss, waste-conscious printing solution that delivers exceptional color quality, consistently.
Color for black-and-white prices
You can afford to print all your documents in attention-grabbing color. -
Only pay for the color you use
With flexible pricing plans, you'll stop paying expensive per-page prices for low-coverage documents. -
The print volume advantage
If you print at least four reams of paper each month, the ColorQube 8880 ADN will deliver a total cost of ownership that's hard to beat. -
Save storage space
Compared to toner, solid ink's smaller packaging is small enough to fit in a desk drawer. -
Spend less on paper and ink
Get standard two-sided printing and the N-up feature, which prints multiple pages on a single sheet. -
Less waste, less environmental impact
Packaging for the printer and Solid Ink sticks generates much less printing waste, lower life cycle energy demand and a smaller carbon footprint than comparable laser printers. -
Earth Smart print driver settings
Easy-to-use print-driver gauge allows you to choose the most environmentally conscious print settings, such as two-sided printing. -
Optimize energy usage
Intelligent Ready technology learns your workgroup's usage patterns and moves to low-power mode when you're least likely to use it. -
More color performance
Solid Ink gives your documents rich, vibrant colors on all media, including recycled paper. PANTONE approved solid-color simulations and Xerox color correction technology deliver results that always match your expectations. Print when you're ready. A first-page-out time as fast as several seconds means your print job's typically ready by the time you walk to the printer.
- Xerox ColorQube 8880_ADN - printer - colour - solid ink
- Printer Type
- Workgroup printer - solid ink - colour
- 27.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 51 ppm - colour
- Image Enhancement Technology
- FinePoint 2400
- Automatic Duplexing
- Interface
- USB, Gigabit LAN
- Processor
- 1 GHz
- RAM Installed (Max)
- 1 GB (2 GB)
- Language Simulation
- PCL 5C, PostScript 3, PDF
- Media Type
- Envelopes, transparencies, labels, plain paper, card stock, punched paper
- Total Media Capacity
- 625 sheets
- Media Handling
- 100-sheet multipurpose tray, 2x 525-sheet input trays
- Monthly Duty Cycle (max)
- 120000 pages
- Networking
- Print server
- System Requirements
- UNIX, Microsoft Windows XP, HP-UX 11i, SunSoft Solaris 9, Microsoft Windows Server 2003, IBM AIX 5.x, SunSoft Solaris 10, Microsoft Windows 7, Red Hat Fedora Core 1, HP-UX 11, Novell Open Enterprise Server, Microsoft Windows Vista, IBM AIX 6.1 or later, Red Hat Fedora Core 5, SuSE Linux 10.x, Microsoft Windows Server 2008, SuSE Linux 11.x
- 1-year warranty
- 40.6 cm x 52.1 cm x 36.8 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- FinePoint 2400
- PostScript Support
- Standard
- First Print Out Time Colour
- 5 sec
- Colour Management Features
- PANTONE Digital Color
- Media Handling
- Processor
- 1 GHz
RAM
- 1 GB / 2 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Legal (216 x 356 mm), 76 x 127 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 625 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 525 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 2200 sheets
- Output Trays Capacity
- 350 sheets
Duty Cycle
- 120000 pages
- Networking
- Print server
- Remote Management Protocol
- HTTPS
- IPsec, 802.1x, IP filtering, SSL 3
- Connections
- 1 x USB - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x solid ink (black) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (cyan) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (magenta) - up to 3200 pages ISO/IEC 24711 , 1 x solid ink (yellow) - up to 3200 pages ISO/IEC 24711
- GOST, EN55024, EN55022 Class A, RoHS, UL 60950-1, EN 60950-1, FCC Part 15 A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 252 Watt
- Power Consumption Stand by
- 104 Watt
- Power Consumption Sleep
- 47 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 80% (non-condensing)
- Sound Emission (Idle)
- 31 dBA
- Sound Emission (Operating)
- 59 dBA
- 40.6 cm
- 52.1 cm
- 36.8 cm
- 27.4 kg
- Width (Shipping)
- 55.9 cm
- Depth (Shipping)
- 67.3 cm
- Height (Shipping)
- 54 cm
- Weight (Shipping)
- 34 kg
