Xerox 6515V_N Colour Multifuntion Printer
Quicklinx: CHSDWS00 Mfr#: 6515V_N?GB
£198.32 ex VAT
£237.98 inc VAT
Pursue relentlessly. Produce effortlessly.
That’s the way to build your business. Introducing the Xerox® Phaser® 6510DN Colour Printer – ready to work right out of the box. Fantastic image quality, easy connectivity, built-in productivity and reliability you can count on, at a price that won’t break the bank.
Spectacular Image Quality
Whatever your business, you’ll put your best face forward with our newest innovation in colour image quality.
Improved toner.
The Phaser 6510DN uses our new Xerox® EA Toner formulation, which has been reengineered for enhanced dot reproducibility and less toner waste. And because it melts at lower temperatures, it saves energy too.
Stunning resolution.
Smaller toner particles translate to finer details, and with 1200 x 2400 native dpi, your printed materials will capture attention and create greater impact.
Colour accuracy
PANTONE® Colour approved solid colour simulations and Xerox® colour correction technology ensure results that match your expectations.
Commanding Performance
Get a handle on day-to-day workloads with the powerful performance your business needs to grow and thrive.
Outstanding performance.
With print speeds up to 28 ppm, the 6510DN is perfectly positioned to support the demands of your growing business.
Print more for longer.
An optional second paper tray (not included) lets you load an extra 550 sheets at one time for extended interruption-free printing.
Time-Saving Taskmaster
Time is money, and these devices are purpose-built to save both by simplifying and automating costly, time-consuming tasks.
Easy management.
Our redesigned Embedded Web Server is easy to use and responsive, so you can easily manage your printer or multifunction printer at your desk or on the go.
Stay secure.
Keep your sensitive documents away from unintended recipients with the latest security features, including IPsec, SNMPv3, IP filtering and secure print.
  • Touch and go
    The color touchscreen offers an app-based, tablet-like user experience. Customize it to match your workflow and navigate with intuitive, smartphone-like interactions.
  • Stunning resolution
  • Outstanding performance
    Perfectly positioned to support the demands of your growing business with print speeds up to 28 ppm.
  • Upwardly mobile
    Print emails, photos and important documents from a wide array of mobile devices, instantly, and without complicated setup with Apple AirPrint, Google Cloud Print, Xerox Print Service Plug in for Android and Mopria.
  • Stay secure
Xerox WorkCentre 6515V_N - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
50000 images
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 600 dpi
Original Size
140 x 140 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets, books
Document Feeder Capacity
50 sheets
Media Size
76.2 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, bond paper, card stock, punched paper, preprinted paper
Standard Media Capacity
300 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
150 sheets
Connection Availability
Gigabit LAN, USB 3.0
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to application, scan to network, Private print, scan to USB host
41.9 cm x 50.5 cm x 50 cm
30.7 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
50000 images
AirPrint Enabled
Standard Memory
2 GB
Max Supported Memory
2 GB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Copying Features
Fit to page, ID Card Copy, Edge Erase, Book Copy, watermark, Image Change
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF
First Print Out Time B/W
12 sec
First Print Out Time Colour
12 sec
Colour Management Features
PANTONE Color Approved
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
MH, MR, MMR, JBIG
Fax Machine Features
Broadcast Transmission
Delayed Transmission
Fax forwarding, Distinctive Ring Pattern Detection (DRPD), junk fax barrier, secure receive
Document & Media Handling
Min Original Size
140 x 140 mm
Max Original Size
Original Type
Sheets, books
50 sheets
Min Media Size
76.2 x 148 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
300 sheets
Max Media Capacity
850 sheets
150 sheets
ADF - 50 sheets size: 140 x 140 mm - Legal (216 x 356 mm) , Input tray - 250 sheets size: 76.2 x 148 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
Gigabit LAN , USB 3.0
Security Protocols & Features
Kerberos, LDAP, IPsec, 802.1x, IP filtering
Operating System Support
SuSe Linux, MS Windows Server 2003, MS Windows 7, MS Windows 2000 Server, HP-UX 11i v2, MS Windows Server 2008, IBM AIX 5, MS Windows Server 2008 R2, Oracle Solaris 10, Oracle Solaris 9, MS Windows Server 2012, Windows 8, Red Hat Fedora Core 12-15, Windows 10, Apple Mac OS X 10.9 or later
Software Included
Xerox CentreWare Web, Xerox PrintingScout
350 Watt
Power Consumption Standby
51 Watt
GOST, GS, NOM, FCC Part 15 B, Directive 1999/5/EC, R&TTE
ENERGY STAR Certified
41.9 cm
50.5 cm
50 cm
30.7 kg
5 °C
32 °C
15 - 85% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Xerox
Price Range Ex VAT: 150 - 300
