Pursue relentlessly. Produce effortlessly.
That’s the way to build your business. Introducing the Xerox® Phaser® 6510DN Colour Printer – ready to work right out of the box. Fantastic image quality, easy connectivity, built-in productivity and reliability you can count on, at a price that won’t break the bank.
Spectacular Image Quality
Whatever your business, you’ll put your best face forward with our newest innovation in colour image quality.
Improved toner.
The Phaser 6510DN uses our new Xerox® EA Toner formulation, which has been reengineered for enhanced dot reproducibility and less toner waste. And because it melts at lower temperatures, it saves energy too.
Stunning resolution.
Smaller toner particles translate to finer details, and with 1200 x 2400 native dpi, your printed materials will capture attention and create greater impact.
Colour accuracy
PANTONE® Colour approved solid colour simulations and Xerox® colour correction technology ensure results that match your expectations.
Commanding Performance
Get a handle on day-to-day workloads with the powerful performance your business needs to grow and thrive.
Outstanding performance.
With print speeds up to 28 ppm, the 6510DN is perfectly positioned to support the demands of your growing business.
Print more for longer.
An optional second paper tray (not included) lets you load an extra 550 sheets at one time for extended interruption-free printing.
Time-Saving Taskmaster
Time is money, and these devices are purpose-built to save both by simplifying and automating costly, time-consuming tasks.
Easy management.
Our redesigned Embedded Web Server is easy to use and responsive, so you can easily manage your printer or multifunction printer at your desk or on the go.
Stay secure.
Keep your sensitive documents away from unintended recipients with the latest security features, including IPsec, SNMPv3, IP filtering and secure print.
- Xerox WorkCentre 6515V_DNI - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 50000 images
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 x 600 dpi
- Original Size
- 140 x 140 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets, books
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, bond paper, card stock, punched paper, preprinted paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 850 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- Gigabit LAN, Wi-Fi(n), USB 3.0
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to application, scan to network, Private print, scan to USB host
- 41.9 cm x 50.5 cm x 50 cm
- 30.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 50000 images
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 2 GB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- Fit to page, ID Card Copy, Edge Erase, Book Copy, watermark, Image Change
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF, TIFF
- First Print Out Time B/W
- 7.4 sec
- First Print Out Time Colour
- 8.7 sec
- Colour Management Features
- PANTONE Color Approved
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- MH, MR, MMR, JBIG
Fax Machine Features
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), junk fax barrier, secure receive
Document & Media Handling
- Min Original Size
- 140 x 140 mm
- Max Original Size
- Original Type
- Sheets, books
- 50 sheets
- Min Media Size
- 76.2 x 148 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 300 sheets
- 850 sheets
- 150 sheets
- ADF - 50 sheets size: 140 x 140 mm - Legal (216 x 356 mm) , Input tray - 250 sheets size: 76.2 x 148 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
- USB 3.0 , Gigabit LAN
- Kerberos, LDAP, IPsec, 802.1x, IP filtering, Wi-Fi Direct
- Operating System Support
- SuSe Linux, MS Windows Server 2003, MS Windows 7, MS Windows 2000 Server, HP-UX 11i v2, MS Windows Server 2008, IBM AIX 5, MS Windows Server 2008 R2, Oracle Solaris 10, Oracle Solaris 9, MS Windows Server 2012, Windows 8, Red Hat Fedora Core 12-15, Windows 10, Apple Mac OS X 10.9 or later
- Software Included
- Xerox CentreWare Web, Xerox PrintingScout
- 350 Watt
- Power Consumption Standby
- 51 Watt
- First Copy Out Time B/W
- 9.7 sec
- First Copy Out Time Colour
- 11.5 sec
- GOST, GS, NOM, FCC Part 15 B, Directive 1999/5/EC, R&TTE
- ENERGY STAR Certified
- 41.9 cm
- 50.5 cm
- 50 cm
- 30.7 kg
- 5 °C
- 32 °C
- 15 - 85% (non-condensing)
Xerox Cyan Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £65.32 |
Xerox Magenta Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £65.46 |
Xerox Yellow Standard Capacity Toner Cartridge (1000 Pages) | In Stock | £65.32 |
Xerox Black Standard Capacity Toner Cartridge (2500 Pages) | In Stock | £84.12 |
Xerox Cyan High Capacity Toner Cartridge (2500 Pages) | In Stock | £124.56 |
Xerox Magenta High Capacity Toner Cartridge (2500 Pages) | In Stock | £124.56 |
Xerox Yellow High Capacity Toner Cartridge (2500 Pages) | In Stock | £124.56 |
Xerox Black High Capacity Toner Cartridge (6000 Pages) | In Stock | £115.76 |
Xerox Cyan Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £145.86 |
Xerox Magenta Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £145.86 |
Xerox Yellow Extra High Capacity Toner Cartridge (4500 Pages) | In Stock | £145.86 |
