Wiz Home Dimmable White 60W E27 Smart Bulb
Quicklinx: H64LWS00 Mfr#: 929002450202
Type: Light bulb
Compatible With: Alexa, Google Assistant, Siri
£6.59 ex VAT
£7.90 inc VAT
Enjoy more convenience in everyday life with this smart WiZ LED A60 bulb. This bulb gives soft white light that dims to your desired brightness level via app or voice. You can set schedule to turn lights on and off according to your daily or weekly routines, and have remote access to your lights even when you're away. WiZ lights connect to your existing Wi-Fi, no additional hardware is needed.
WiZ - LED light bulb - shape: A60 - frosted finish - E27 - 8 W - warm white light - 2700 K
Light Source Type
LED light bulb
Shape
A60
Bulb Finish
Frosted
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
806 lumens
Dimmable
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
Nest, SmartThings, ecobee, Ring
Communications Technology
Bluetooth, Wi-Fi
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Light Source
LED light bulb
Shape
A60
Bulb Finish
Frosted
Socket Type
E27
Wattage
8 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
8 kWh
Lamp Current
70 mA
Warm white light
Colour Temperature
2700 K
Colour Rendering Index
90
Colour Code
927
Luminous Power
806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Indoor usage, light scheduling, app-controlled
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Bluetooth, Wi-Fi
Compatible Services
IFTTT
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
Diameter
60 mm
Length
122 mm
60 g
7 cm x 7 cm x 16 cm
Type: Light bulb
Compatible With: Siri
Brand: Wiz Home
