Product
Wiser Thermostat Kit 3 for Conventional Boilers with Two Heating Zones
Quicklinx: D4YZWS00 Mfr#: WT734R9K0902
Type: Thermostat kit
Compatible With: Alexa
£183.33 ex VAT
£219.99 inc VAT
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
Three channel thermostat pack idea for larger properties with two heating zones. Enables you to control heating and hot water via the Wiser Heat app. Your existing cylinder thermostat can be wired in for hot water control.
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
  • Multi-zoning - build the perfect system by adding Radiator Thermostats as required
  • Works with Amazon Alexa
  • Eco Mode - combines weather compensation & optimum stop for maximum savings
  • Simplicity - standard wallplate, wireless devices
  • Remote Control - simple app with boost & away mode
  • OpenTherm® technology
Kit contains:
  • 2 x Room thermostat
  • 1 x 3 channel Heat Hub®
  • 2 x Thermostat stand
  • 2 x Thermostat wall bracket
  • 4 x AA batteries
  • 1 x OpenTherm module
  • 1 x Wallplate
Drayton Wiser Thermostat Kit 3 - thermostat kit
Thermostat kit
Functions
Humidity measurement
Power Source
Package Content
System hub, control interface module, 2 thermostats
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Display
2.4" - LCD
7.6 cm x 2.5 cm x 7.6 cm
Thermostat kit
Functions
Power Source
Package Content
Wireless - WiFi
Max Range Indoors
30 m
Frequency Band
2.4 Ghz
3 channels
Internet of Things (IoT)
Display
2.4" - LCD
2 stands, wall plate, 2 mounting brackets
Battery Required
2 x AA type - Alkaline
RoHS, IP20, Directive 2006/66/EC, Directive 2011/65/EU, EN 300 328, Directive 2014/53/EU, EN 60730-1, EN 60730-2-7
7.6 cm
2.5 cm
7.6 cm
45 °C
Brand: Wiser
Price Range Ex VAT: 150 - 300
