Wiser Thermostat Kit 1 for Combi Boilers
Quicklinx: D4YVWS00 Mfr#: WT714R9K0902
Introducing Wiser, the beautifully simple multi-zone heating system from Drayton. Easy to install from app to thermostat, Wiser is the altogether better, smarter, easier way to personalise home heating with up to 16 zones and hot water.
One channel thermostat pack ideal for combi-boilers. Enables you to control heating via the Wiser Heat app
What makes Wiser wiser.
Wiser makes home personalisation affordable by allowing you to start with a room thermostat and build a full multi-zone system over time by adding radiator thermostats. Simply unscrew the existing radiator valve heads and screw on your new Wiser Radiator Thermostats.
  • Multi-zoning - build the perfect system by adding Radiator Thermostats as required
  • Works with Amazon Alexa
  • Eco Mode - combines weather compensation & optimum stop for maximum savings
  • Simplicity - standard wallplate, wireless devices
  • Remote Control - simple app with boost & away mode
  • OpenTherm® technology
Kit contains:
  • 1 x Room thermostat
  • 1 x 1 channel Heat Hub®
  • 1 x Thermostat stand
  • 1 x Thermostat wall bracket
  • 2 x AA batteries
  • 1 x OpenTherm module
  • 1 x Wallplate
Drayton Wiser Thermostat Kit 1 - thermostat kit - Wi-Fi
Thermostat kit
Power Source
Package Content
Thermostat, system hub, control interface module
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Display
2.4" - LCD
7.6 cm x 2.5 cm x 7.6 cm
Thermostat kit
Power Source
Package Content
Wireless - Wi-Fi
Max Range Indoors
30 m
Frequency Band
2.4 Ghz
Display
2.4" - LCD
1 channel
Temperature Range
5 - 30 °C
Measurement Accuracy
±0.5 °C
Thermostat
Humidity sensor
AA type
Battery Included
Required Qty
2
Alkaline
Stand, wall plate, wall mount bracket
IP20
7.6 cm
2.5 cm
7.6 cm
45 °C
25 - 90% (non-condensing)
