WD Ultrastar Serv24 Xeon Gold 6140 153.6TB (24 x 6.4TB SN200) 24 Bay NVMe Rack NAS
Quicklinx: DXLSWS00 Mfr#: 1ES1015
There is a never-ending need to increase data center performance for storage-intensive applications. To fully realize the benefits of a software-defined storage (SDS) infrastructure, purpose-built storage platforms have become the preferred building blocks for many enterprise data centers. The Ultrastar Serv24 is designed to be a performance-optimized platform for SDS.
  • The storage server platform for software-defined storage
  • Designed for fast data
    Flash technology has revolutionized the performance of storage systems; NVMe technology extends flash storage to its full potential. Built upon the storage expertise, the Ultrastar Serv24 features the advanced CPUs. Chipset, core count and power can be customized, providing the flexibility to meet varying requirements depending on data workload and performance requirements. Whether as a stand-alone file server or part of a scale-out deployment, the Ultrastar Serv24 is built to deliver screaming performance in software-defined storage environments. With low latency and consistently high bandwidth, data is accelerated to the speed of flash.
WD Ultrastar Serv24 SS2U24PUR-1027 - NAS server - 153.6 TB
NAS server
Host Connectivity
10 Gigabit Ethernet
Enclosure Type
2U
Total Storage Capacity
153.6 TB
24 (installed) / 24 (max)
44.8 cm x 76 cm x 8.7 cm
24.9 kg ()
1 x Intel Xeon Gold 6140 2.3 GHz (18-core)
Storage Controller
PCI Express PCI Express 3.0 x4
Hard Drive
24 x 6.4 TB PCI Express 3.0 x4 - Secure Erase function, Enterprise, NVM Express (NVMe) - HGST
Hard Drive (2nd)
2 x 512 GB
10GbE
RAM
256 GB
AC 230V
Power Redundancy
NAS server
Host Connectivity
10 Gigabit Ethernet
Enclosure Type
2U
153.6 TB
44.8 cm
76 cm
8.7 cm
24.9 kg ()
Processor / Memory
Processors Installed
Number of Cores
18-core
RAM
256 GB DDR4
Storage Controller
PCI Express
Interface Type
PCI Express 3.0 x4
Hard Drive
SSD - hot-swap - 2.5"
24 x 6.4 TB
Interface Type
PCI Express 3.0 x4
Manufacturer
HGST
Drive Writes Per Day (DWPD)
3
Hard Drive (2nd)
SSD
2 x 512 GB
10GbE
Remote Management Protocol
IPMI 2.0
Hot swappable 5+1 60mm fans
OCP 2.0
Expansion Bays
24 (total) / 0 (free) x internal - 2.5"
Expansion Slots
2 x PCI Express 3.0 x16 , 1 x PCI Express 3.0 x8
2 x Ethernet 10Gb , 1 x Ethernet 1000 (management) - RJ-45 , 2 x USB 3.0 , 1 x VGA , 1 x serial - DB-9
Hot-plug
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V
Power Provided
1200 Watt
80 PLUS Certification
80 PLUS Platinum
5 °C
35 °C
5 - 85%
