WD Ultrastar Data60 720TB SATA (60 x 12TB He12) 60 Bay Rack NAS
Quicklinx: DXJGWS00 Mfr#: 1ES0368
Type: Storage enclosure
Controller Type: None
£22,246.62 ex VAT
£26,695.94 inc VAT
The Ultrastar Data102 is a key element of next-generation disaggregated storage and software-defined storage (SDS) systems, delivering extreme density and the flexibility to balance performance with cost. Conventional dense disk shelves frequently suffer from performance degradation due to induced vibration from adjacent drives. Traditional platforms also have cooling challenges as the cooling air passes over successive rows of drives, losing effectiveness as it gets heated up along the airflow path.
  • High density
    Up to 720TB raw capacity in a 4U enclosure.
  • Flexible
    Choice of SAS or SATA with option for a flash data acceleration tier.
  • Innovative
    IsoVibe and ArcticFlow for improved performance, cooling, and TCO.
WD Ultrastar Data60 SE-4U60-12F24 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Total Array Capacity
720 TB
Max Supported Capacity
720 TB
60 (installed) / 60 (max)
Supported Drives
SATA-600 / SAS-3
Hard Drive
60 x 12 TB HDD SATA 6Gb/s - hot-swap - Instant Secure Erase (ISE), 512e Crypto
AC 230V - 50/60 Hz
Power Redundancy
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Chassis
60
Supported Devices / Modules Qty
60
Supported Drives
SATA-600 / SAS-3
Storage
720 TB
720 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
60 x 12 TB
Interface Type
SATA 6Gb/s
Expansion Bays
60 (total) / 0 (free) x hot-swap - 3.5"
SAS 12Gb/s
SCSI Enclosure Services 3 (SES3)
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V - 50/60 Hz
Power Provided
1600 Watt
Limited warranty - 5 years
5 °C
35 °C
8 - 80% (non-condensing)
Brand: WD
Price Range Ex VAT: £1500+
