WD Ultrastar Data60 720TB SAS (60 x 12TB He12) 60 Bay Rack NAS
Quicklinx: DXJDWS00 Mfr#: 1ES0362
Type: Storage enclosure
Controller Type: None
£21,855.84 ex VAT
£26,227.00 inc VAT
The Ultrastar Data60 hybrid storage platform is a key element of next-generation disaggregated storage and Software-Defined Storage (SDS) systems. The compact, efficient form factor provides the flexibility to specify the HDD and SSD combinations for balancing capacity, performance, and cost.
A flash data acceleration tier can be enabled to serve both fast data and big data applications from a single platform. The Ultrastar Data60 addresses the demanding storage needs of large enterprise customers, storage OEMs, cloud service providers, as well as resellers/integrators requiring dense, shared HDD or hybrid storage.
WD Ultrastar Data60 SE-4U60-12F04 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Max Supported Capacity
720 TB
60 (installed) / 60 (max)
Supported Drives
SAS-3
Hard Drive
60 x 12 TB HDD SAS 12Gb/s - hot-swap - Instant Secure Erase (ISE), advanced format 512e
AC 230V - 50/60 Hz
Power Redundancy
44.7 cm x 71.2 cm x 17.5 cm
79.4 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Chassis
60
Supported Devices / Modules Qty
60
Supported Drives
SAS-3
Storage
720 TB
Hard Drive
HDD - hot-swap
60 x 12 TB
Interface Type
SAS 12Gb/s
Expansion Bays
60 (total) / 0 (free) x hot-swap - 3.5"
SAS 12Gb/s
SCSI Enclosure Services (SES), IsoVibe vibration isolation technology, ArcticFlow thermal zone cooling technology
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V - 50/60 Hz
Power Provided
1600 Watt
80 PLUS Certification
80 PLUS Platinum
44.7 cm
71.2 cm
17.5 cm
79.4 kg
Limited warranty - 5 years
5 °C
5 - 85%
Brand: WD
Price Range Ex VAT: 1500+
