The Ultrastar Data60 hybrid storage platform is a key element of next-generation disaggregated storage and Software-Defined Storage (SDS) systems. The compact, efficient form factor provides the flexibility to specify the HDD and SSD combinations for balancing capacity, performance, and cost.
A flash data acceleration tier can be enabled to serve both fast data and big data applications from a single platform. The Ultrastar Data60 addresses the demanding storage needs of large enterprise customers, storage OEMs, cloud service providers, as well as resellers/integrators requiring dense, shared HDD or hybrid storage.
Designed for the enterprise and the cloud
The Ultrastar Data60 provides the flexibility to specify the HDD and SSD combinations to balance capacity, performance and cost. -
IsoVibe vibration isolation technology
Precise cuts in the baseboard provide a suspension for the drives in the chassis, isolating them from transmitted vibration. The result is that consistent performance is maintained, even when all the drives are working hard. -
ArcticFlow thermal zone cooling technology
By introducing cool air into the center of the chassis, drives operate at lower and more consistent temperatures than conventional systems. This results in lower fan speeds, reduced vibration, lower power consumption, quieter operation and ultimately higher reliability.
- WD Ultrastar Data60 SE-4U60-10F04 - storage enclosure
- Storage enclosure
- Enclosure Type
- Rack-mountable - 4U
- Max Supported Capacity
- 720 TB
- Installed Devices / Modules Qty
- 60 (installed) / 60 (max)
- Supported Drives
- SAS-3
- Hard Drive
- 60 x 10 TB HDD SAS 12Gb/s - hot-swap - Instant Secure Erase (ISE), advanced format 512e
- Power
- AC 230V - 50/60 Hz
- Power Redundancy
- 44.7 cm x 71.2 cm x 17.5 cm
- 79.4 kg
- 5-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- 60
- Supported Devices / Modules Qty
- 60
- Supported Drives
- SAS-3
Storage
- 720 TB
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 60 x 10 TB
- Interface Type
- SAS 12Gb/s
- Expansion Bays
- 60 (total) / 0 (free) x hot-swap - 3.5"
- SAS 12Gb/s
- SCSI Enclosure Services (SES), IsoVibe vibration isolation technology, ArcticFlow thermal zone cooling technology
- Power Device
- 2 x internal power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 1600 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- 44.7 cm
- 71.2 cm
- 17.5 cm
- 79.4 kg
- Limited warranty - 5 years
- 5 °C
- 40 °C
- 5 - 85%
