WD Ultrastar Data60 600TB SAS (60 x 10TB He10) 60 Bay Rack NAS
Quicklinx: DXJBWS00 Mfr#: 1ES0350
Type: Storage enclosure
Controller Type: None
£19,855.90 ex VAT
£23,827.08 inc VAT
The Ultrastar Data60 hybrid storage platform is a key element of next-generation disaggregated storage and Software-Defined Storage (SDS) systems. The compact, efficient form factor provides the flexibility to specify the HDD and SSD combinations for balancing capacity, performance, and cost.
A flash data acceleration tier can be enabled to serve both fast data and big data applications from a single platform. The Ultrastar Data60 addresses the demanding storage needs of large enterprise customers, storage OEMs, cloud service providers, as well as resellers/integrators requiring dense, shared HDD or hybrid storage.
  • Designed for the enterprise and the cloud
    The Ultrastar Data60 provides the flexibility to specify the HDD and SSD combinations to balance capacity, performance and cost.
  • IsoVibe vibration isolation technology
    Precise cuts in the baseboard provide a suspension for the drives in the chassis, isolating them from transmitted vibration. The result is that consistent performance is maintained, even when all the drives are working hard.
  • ArcticFlow thermal zone cooling technology
    By introducing cool air into the center of the chassis, drives operate at lower and more consistent temperatures than conventional systems. This results in lower fan speeds, reduced vibration, lower power consumption, quieter operation and ultimately higher reliability.
WD Ultrastar Data60 SE-4U60-10F04 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Max Supported Capacity
720 TB
60 (installed) / 60 (max)
Supported Drives
SAS-3
Hard Drive
60 x 10 TB HDD SAS 12Gb/s - hot-swap - Instant Secure Erase (ISE), advanced format 512e
AC 230V - 50/60 Hz
Power Redundancy
44.7 cm x 71.2 cm x 17.5 cm
79.4 kg
5-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 4U
Chassis
60
Supported Devices / Modules Qty
60
Supported Drives
SAS-3
Storage
720 TB
CPU
No CPU
Hard Drive
HDD - hot-swap
60 x 10 TB
Interface Type
SAS 12Gb/s
Expansion Bays
60 (total) / 0 (free) x hot-swap - 3.5"
SAS 12Gb/s
SCSI Enclosure Services (SES), IsoVibe vibration isolation technology, ArcticFlow thermal zone cooling technology
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
AC 230V - 50/60 Hz
Power Provided
1600 Watt
80 PLUS Certification
80 PLUS Platinum
44.7 cm
71.2 cm
17.5 cm
79.4 kg
Limited warranty - 5 years
5 °C
5 - 85%
Brand: WD
Price Range Ex VAT: £1500+
